john wrote:Epoxy. Smelled just like bondo.
Both make me loopy!
goldcoop wrote:Steve-
I don't know if this helps, but it is interesting!
http://www.retroteardrop.com/project/build/fender1.php
Cheers,
Coop
madjack wrote:there would be no problems with a torsion axle since the torsion arms go straight up and down...onna spring axle there could be clearance issuessince they travel in an arc
It appears that the front of the fender is wider than the rear??
john wrote:On mine the front is about 1" wider and it is not a resut of my repair. The repair did't extend to either end of each fender and both fenders have the same 1" increase in width at the front.
