Mike-n-Britney wrote:Great idea! I can't say I've heard of anyone doing anything like this, but I'm pretty new here myself... I really like this idea, and am interested to see how the project progresses! So do you have the equipment/capabilities to mold/shape the pieces to get your radiused joints?
After considering this, it would be really nice to have all the pieces water-jet cut, then formed, then simply bond all the pieces together like a big model! With a proper design, this has tremendous mail-order kit potential!
angib wrote:Interesting. Is the build method to assemble the core and then laminate skins onto both sides, plus fair the outer skin?
Lightweight is good, but if you're building 5' x 12', it sounds like you want to fill up the inside which raises two issues:
- you need to build the interior cabinetry as light as the exterior;
- you have to not put anything in the interior cabinets.
I think the structural side needs to be looked at again. Just by gut feel, a 1-1/2" core in the floor seems total overkill - the unsupported areas of the floor are not that big even with a simple triangle chassis and this is not a house where you can walk on the floor. The floor does not support the body - it's the sidewalls that do that - the floor just stops the occupants falling out.
On the other hand, 1/2" core for the sides and roof sounds pretty thin. Core thickness needs to reflect panel width (that is, the lesser of length or width) and for the roof that's the 5 foot width. In contrast a kayak has 'panels' only 8" wide - giving bending moments only 1/50th as big. 15oz is generous as a skin weight but core thickess matters much more. 3/4" core feels more sensible to me.
For hatch rims and door frames, practicality says wood inserts are best. Wood (or an expensive alternative) will also be required at attachment points like where the body bolts to the chassis.
I don't think the hatch needs any rim - trailer hatches screw/bolt down to a flat surface so it just needs a wood frame instead of the core, to screw/bolt to/through. For the doors, the easiest thing might be to let a wide wood frame (maybe 1x4) into the core material, laminate both sides and then cut along the centre of the wood, leaving a laminated-in wood frame in both the sidewall and the door blanks.
The rounded profile on the roof-to-wall joint sounds like pie in the sky to me - this is maybe 100 times more difficult than the hatch and door question. I don't think it's even worth thinking about - just go for a regular square joint.
I haven't used this core material so I don't know how much in-plane stiffness it has. If one skin could be laminated to the core and then the result bent around the relatively large curves of a teardrop, the work saved would be enormous as the second skin could be restricted to the outside where it's so much easier to work.
Thomcat316 wrote:....all I need is a good female mould and a source of vacuum to pull the core down with. Throw a bit of heat on it, let it cool, then bag a skin onto it and it won't even spring back when unmoulded.
Thomcat316 wrote:I've done some browsing around here for a while, and finally became a member.
I saw the design links for the Superleggera (http://www.angib.pwp.blueyonder.co.uk/t ... tear32.htm) teardrop, which struck a loud chord in me, so i decided to do a bit of research and planning to see what I could come up with m'self.
Plans at the moment are to build a fiberglass and honeycomb monocoque box to be mounted on the axle and triangular frame of the SL design, using the stiffness of the floor panel (1-1/2" cored panel made of http://www.plascore.com/pdf/PP_Honeycomb.pdf and 15oz. fiberglass roving) to avoid relying on the frame for stiffness.
Sidewalls and top will be made of 1/2" honeycomb with the same roving for skin. I know I could go MUCH lighter with the skin, but I don't think it's necessary and I like the impact resistance of the heavier 'glass.
Floor-to-sidewall joints will be the usual right angles, with roof-to-sidewall being a rounded profile of about 3"-4" radius.
Overall footprint is about 5'x12' (yup, we're going for big *and* light here...) with a height above ground of 3" taller than my 1997 Subaru wagon.
What I'd like to know is if anyone's done a superlight cored trailer here before. I know my way around cored construction, so that's not a mystery, but I'd like some information about how to best design a molded hatch rim that won't leak, and suggestions for the same for doors. Ultralight kayaks don't have doors....
Thanks!
Whitney
angib wrote:Thomcat316 wrote:....all I need is a good female mould and a source of vacuum to pull the core down with. Throw a bit of heat on it, let it cool, then bag a skin onto it and it won't even spring back when unmoulded.
Fine - if that's "all" you need, then that's my 100 times more work explained!
If I were going this far, I would be tempted to use a complete male plug for the top and sidewalls, building from the inside outwards so access and vacuuming was easy, and then take the bottom-less body off the plug and join it to a completed floor. OK, you have to fair the outer surface but you have to do that sometime anyway even if it's making a male plug to take a female mould from.
