Silver Beatle - She's now with an old friend!
Postby Rlowell » Sun Dec 19, 2010 6:27 pm
:applause: :applause: Tom,
That is some great work. If I was that far along I would have already had a long weekend!! As you can tell, I have a long way to go.
Keep up the good work!
Rod
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby Justin & Katy » Mon Dec 20, 2010 2:02 pm
Your build looks great, Tom! I really like the tail lights. I think we have the same license plate bracket.
Justin & Katy
Images: 81
Postby planovet » Mon Dec 20, 2010 3:52 pm
aggie79 wrote:And.....drum roll please....I installed the gas struts for the hatch. It worked great! :applause: And there are only two extra holes. :cry: These should be hidden (almost).
Not bad, I had three. :lol:
Looks good Tom! :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby aggie79 » Mon Jan 31, 2011 11:19 pm
:? I can't believe it has been almost six weeks since I've last posted an update. Most of the time has been spent doing a lot of uninteresting details.
I do have my HVAC almost in order. I'm using a Petcool mounted in a tongue box. The supply air is ducted through the back of the tongue box and front of the teardrop to two supply grills at the top of my front cabinet. The return air is ducted through the bottom of the tongue box and back underneath the teardrop to the bulkhead. In this picture I was mocking up the openings in the tongue box.
For the return air duct, I used a 2" x 3" downspout. It was covered with 2 layers of 1/4" "bubble wrap" insulation and then an outer 3" x 4" downspout.
This is a picture of the return air duct at the front of my teardrop running back to the bulkhead.
At the bulkhead, the return air duct will end in a mini plenum that I built to hold a 12" x 12" filter. (The teardrop side of the plenum has a return air grill.)
I next focused my attention on the galley. I installed a 1/2" plywood counter.
Then I insulated the upper bulkhead wall and installed the engineered flooring that I'm using as a wall finish material. (The lower part of the bulkhead was finished some time ago.)
I then built the lower cabinet face frame. This is a picture of it on the bench prior to assembly. (The plywood cleats help keep everything square and parallel.)
And here is a picture of it mocked up in place.
(The black area in the galley is where the return air plenum and filter will be.)
I am now switching my attention - pun intended - to completing the teardrop electrical system.
Thanks for looking and Gig'em!
Postby S. Heisley » Mon Jan 31, 2011 11:22 pm
Tom, your build just keeps getting better and better! :thumbsup: :applause:
Postby Rlowell » Tue Feb 01, 2011 12:06 am
Looking great there Tom!! You will be ready for spring break.
(Wish that I could be.)
Rod
Rlowell
Images: 42
Postby aggie79 » Tue Feb 01, 2011 12:47 am
Thanks Sharon and Rod. Your nice comments keep me moving forward.
I just found out that my work will be closed tomorrow because of a winter storm. (We don't know how to handle them here). So, if I can get a little heat in the garage, I'll get some more done tomorrow.
Postby 2bits » Tue Feb 01, 2011 1:49 am
Hey Tom, I love the way the galley looks! That is sweet!
Thomas
2bits
2bit Member
very nice
Postby 3822sean » Tue Feb 01, 2011 2:46 am
:thumbsup: :thumbsup: :thumbsup: that looks sweet very nice work
3822sean
Images: 37
Postby aggie79 » Tue Feb 01, 2011 5:34 am
Postby Rlowell » Tue Feb 01, 2011 8:37 am
aggie79 wrote:Thanks Sharon and Rod. Your nice comments keep me moving forward.
Heat up the garage and stay safe today. Looks like a bad storm.
Pray that everyone is safe and warm.
Rod
Rlowell
Images: 42
Postby aggie79 » Tue Feb 01, 2011 9:04 am
2bits wrote:Hey Tom, I love the way the galley looks! That is sweet!
Thanks, Thomas.
I had to make some compromises with my galley layout. One of them was to not have a place for a cooler. I'm fastening the face frames and cases withscrews only in case I want to change my galley design later.
Taken are and I'll see ya at Beavers Bend if not sooner.
Postby 2bits » Tue Feb 01, 2011 11:35 am
Hey Tom,
The cooler thing might be a blessing in disguise. I have only used my big cooler a couple times actually. Maybe it would be different if I packed more stuff, some people bring alot of food and drink. For my usage, I have to small coolers, one for food and one for drink, I just don't bring enough of any one thing to fill up that huge cooler. I like my medium sized one that is one wheels pretty good these days too. The only I think I use it for now is to bring spare ice for longer trips.
Thomas
2bits
2bit Member
Postby starleen2 » Tue Feb 01, 2011 11:54 am
Tom - are you outta that blue tape yet? I have a theory that you'll be finished when you use that LAST roll of tape - Just razzin' ya tom - the extra time and effort really shows in your craftsmanship and attention to detail. Stay warm now :thumbsup:
starleen2
5th Teardrop Club
Postby DMcCam » Tue Feb 01, 2011 4:32 pm
Your galley is looking very nice Tom! Are you planning on upper cabinets too? She sure is a sweetheart of a teardrop. Thanks for the updates!
All the Best,
Dave
DMcCam
Users browsing this forum: Bing [Bot] and 12 guests
