How did you attach the fenders???
Postby TheBizMan » Mon Feb 14, 2011 8:28 pm
Did you run bolts thru the side walls? If so how did you keep them from poking the mattess? OR did you weld them to the frame? OR what else.
:? :worship:
Lee - TheBizMan sez
Teardrops make for happy camping
TheBizMan
Postby CliffinGA » Mon Feb 14, 2011 8:45 pm
Ran short bolts thru wall with the bolt head on inside and nut on outside so no poking on inside. Short bolts will hold it on and no issue with them hitting the wheels.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
bolts
Postby mvperini » Mon Feb 14, 2011 8:53 pm
I used carriage bolts with the head on the inside of the trailer
Mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Re: bolts
Postby aggie79 » Mon Feb 14, 2011 10:15 pm
mvperini wrote:I used carriage bolts with the head on the inside of the trailer
Mike
So did I.
First I positioned the fenders in place to see where I thought they looked good. Then I marked the outline on the sidewalls.
To make sure I drilled the holes in the right location, I made a template from MDF by tracing the fender flange and clamped it to the sidewalls.
After the holes were drilled, I squirted sealant in each of the holes and inserted the carriage bolts. This is the inside view.
And here's the outside view,
After adhering welting to the fender flange, I squirted some more sealant around the carriage bolt and bolted the fenders using fender wash and nylok nuts. Finally, I used a hack saw to cut off the excess carriage bolt length.
Take care,
Postby ME87 » Mon Feb 14, 2011 11:30 pm
I know it's not common tear drop practice, but if you're running a standard live axle and not a torsion, you could attach the fenders to the axle. This allows you to greatly minimize the distance between the tire and fender, because the fender is no moving with the tire. This creates a really clean look. I did this on a motorcycle trailer and it worked great. Just a thought
ME87
Re: How did you attach the fenders???
Postby KenC » Mon Feb 14, 2011 11:52 pm
TheBizMan wrote:Did you run bolts thru the side walls? If so how did you keep them from poking the mattess? OR did you weld them to the frame? OR what else.
:? :worship:
I attached mine to the frame fabricated and weled in place. My album and blog will show some of the details.
KenC
Images: 41
Postby madjack » Tue Feb 15, 2011 11:02 am
...3/4"ply sides...ran elevator bolts(similar to carriage blots with wider /flatter heads) from inside out to attach fenders...used 3/16x1" closed cell/ foam weatherstripping on fender mounting flange edge as welting/sealing material...works well...................
madjack 8)
p.s. gottem at Fastenal.........................mj
Postby TheBizMan » Tue Feb 15, 2011 3:06 pm
Thanks for everyones input. I'm just about ready to put them on.
Thanks Jack, I found the elevator bolts at Lowes.
Lee - TheBizMan sez
TheBizMan
