Where or When Jr. --Paint & New Tow Vehicle--update 5/17/15
Postby myoung » Thu Feb 24, 2011 7:20 pm
Well, this is really overkill and a waste of a day or more. When I designed the walls, I simply extended the sidewalls over part of the wheel wells to make a trapezoidal opening.
What I should have done was to fabricate these wheel well openings with a single sheet of 3/4-inch plywood rather than 7 pieces of poplar, 2 skins of Luan plywood, and insulation in the interstices.
Yesterday, Dad flew back to Boston so I'm back to working mostly solo. I skinned the perimeter sides and the rear of the rooftop. Still have to figure out just how to configure the front faring to match the front edge of the pop-up by extending the angled front upper panel.
Mike Young
myoung
Images: 250
Postby vtx1029 » Fri Feb 25, 2011 12:16 am
Did ya try taking a wheel off? Looks tight from the pictures :thinking:
vtx1029
Images: 70
Postby myoung » Fri Feb 25, 2011 12:39 am
vtx1029 wrote:Did ya try taking a wheel off? Looks tight from the pictures :thinking:
Yup. There is clearance.
Mike Young
myoung
Images: 250
Postby pete42 » Fri Feb 25, 2011 11:08 am
I was glad to see a father and son working together I lost my father when he was only 62 I'm 69 what I once thought was old (62) I now think of as young.
nice build and you already have memories that will last a life time.
having been an electrician for 41 years yep a bigger box would have been better but it's installed and works.
pete
pete42
Postby myoung » Fri Feb 25, 2011 11:32 pm
Among today's tasks was fabricating the fairing or wind deflector at the top of the front of the trailer. To the upper 1.5-inch frame, I spliced two more pieces: one a 2.5-inch wide piece that runs the full width of the trailer, and one a 3.5-inch wide piece that is 4 feet long to match the width of the pop-up top.
Later, I'll round the leading edges and box in a section to fit between the pop-up top front edge and the trailer.
Mike Young
myoung
Images: 250
Postby droid_ca » Sat Feb 26, 2011 1:15 am
Mike your build just gets better and better I can't wait to see more I love the detailed pictures great sorce of inspiration :applause: :thumbsup: :applause: :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby myoung » Tue Mar 01, 2011 10:52 am
I can see the end of body construction now. All I need is one more sheet of 5mm Luan plywood. So, off to Home Depot only to discover that the stack of 20 or more sheets that I have been purchasing a few at a time has been reduced to ZERO.
I'll work on odds and ends like drawers until the plywood supply is replenished.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Tue Mar 01, 2011 12:03 pm
myoung wrote:I can see the end of body construction now. All I need is one more sheet of 5mm Luan plywood. So, off to Home Depot only to discover that the stack of 20 or more sheets that I have been purchasing a few at a time has been reduced to ZERO.
Mike, there are at least 5 Home Depots in the general area. Perhaps they would call other stores for you for availability?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby myoung » Tue Mar 01, 2011 12:09 pm
Yes, Cliff, I'll try one of the other if the wait delays my work. For the time being, I'm okay with the chance to do some interior work.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Tue Mar 01, 2011 12:15 pm
You gonna load up the Airstream and come to Usery Mountain Park this weekend?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby myoung » Tue Mar 01, 2011 1:50 pm
Cliffmeister2000 wrote:You gonna load up the Airstream and come to Usery Mountain Park this weekend?
No. I want to continue working on my TTT. Time's a wastin'.
Mike Young
myoung
Images: 250
Postby mezmo » Thu Mar 03, 2011 11:46 pm
Hi Mike,
Check out Cliff Uyeda's recent album on his website:
http://www.salsaholics.com/trailer/gall ... modernism/
Page 2 and 5 have pics of a neat Pop-Top pickup camper someone
built probably in the 60s. Interesting work and careful craftsmanship.
I thought it close in concept to your and Sharon's builds.
You're making great progress on yours!
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby myoung » Fri Mar 04, 2011 12:29 am
I can see that the start of painting and finishing isn't too far away. Time to finish up some interior and exterior details so that the application of CPES on the outside and primer on the inside can begin.
Here is a photo of the rotating support arm for the table. This is an item from a VW Camper circa 1990. The hole in the counter top is a bit too large so I'll have to find a new grommet or some other way to tighten up the opening.
After trying several configurations of the stove top, we decided on this somewhat unconventional diagonal arrangement. It leaves room for utensils and perhaps a lid alongside the stove with just enough room around it so as not to feel cramped.
The front of the roof will have to be fitted with a cowling to deflect the air over the pop-up top. I'll round the front edges a bit and make a cowling will just enough clearance to accommodate the top as it moves up and down. The opening for the linear actuator shouldn't be too hard to weatherize. Details to follow.
This is only about half or a third as high as the front of the pop-up will be extended.
Mike Young
myoung
Images: 250
Postby myoung » Sun Mar 06, 2011 7:04 pm
Nothing much to show except a sea of white primer paint over every nook and cranny of the interior. Took all day with a brush and roller so I won't be giving the spaces inside and behind cabinets, doors, and drawers a second coat.
Mike Young
myoung
Images: 250
Postby H-Balm » Mon Mar 07, 2011 5:07 am
Your sliding cabinet looks fantastic.
You two have some pretty nice woodworking skills.
H-Balm
Users browsing this forum: featherliteCT1 and 8 guests
