Camp Critter update 11/6/2013
Postby GeoDrop » Wed Mar 23, 2011 7:59 am
LDK wrote:I don't think I'll be making my ribs out of that 3/4" ply I have. After cutting it out I found out it has major void issues.
:D
Matthew (& Sandi)
The GeoDrop
GeoDrop
Postby LDK » Wed Mar 23, 2011 6:06 pm
I'm close to being done with the galley. Maybe I should have done that pesky ole hatch lid first. :o :lol:
LDK
Postby S. Heisley » Wed Mar 23, 2011 9:15 pm
Pretty! :D
Nice job! :thumbsup:
Postby LDK » Thu Mar 24, 2011 8:44 pm
Well I got the ribs cut out and they seem pretty stout. That southern yellow pine is gonna work out good for me. I framed it up and left a 1/4" gap all around but the bottom has alittle bit bigger gap, :o --measurement error--. I sure hope I can work around it. :thinking:
LDK
Postby CliffinGA » Thu Mar 24, 2011 8:48 pm
Larry can you make the bottom cross piece thicker to fix it? Or add to it?
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby LDK » Thu Mar 24, 2011 8:50 pm
CliffinGA wrote:Larry can you make the bottom cross piece thicker to fix it? Or add to it?
Cliff
I was thinkin the same thing Cliff :)
LDK
Postby CliffinGA » Thu Mar 24, 2011 8:54 pm
better yet make the top thicker as thats where most of the weight and stress will be on the hatch right?
Cliff
My Build:
CliffinGA
Images: 207
Postby LDK » Thu Mar 24, 2011 9:00 pm
CliffinGA wrote:better yet make the top thicker as thats where most of the weight and stress will be on the hatch right?
Cliff
I'm gonna add more oak to the top and bottom anyway but I could probably glue a really thin piece to the bottom to close up the gap alittle. Just by looking at it , it looks like maybe 3/8" when I was shootin for 1/4". :thinking:
LDK
Postby CliffinGA » Thu Mar 24, 2011 9:31 pm
Arry how much did you notch your sides for your hatch? 3/8"?
Cliff
My Build:
CliffinGA
Images: 207
Postby LDK » Thu Mar 24, 2011 9:46 pm
CliffinGA wrote:Arry how much did you notch your sides for your hatch? 3/8"?
Cliff
It's pretty much 1/4" except for the bottom. I used 1/4" shims all around it.
LDK
Postby Loader » Thu Mar 24, 2011 9:55 pm
Looks good Larry. The pine should work out well. Agree laminating a little extra shim piece should take care of the gap.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby LDK » Thu Mar 24, 2011 9:57 pm
Cliff,
If you can you should try using a 2x10 or a 2x12 southern yellow pine board to make your ribs out of. If your rib profile isn't too wide. I paid only $14.00 for the board I used. :thumbsup:
LDK
Postby LDK » Thu Mar 24, 2011 10:04 pm
Loader wrote:Looks good Larry. The pine should work out well. Agree laminating a little extra shim piece should take care of the gap.
Thanks Earl, I guess when I'm ready to skin and hinge it I'll add what is necessary to close the gap alittle.
LDK
Postby LDK » Fri Mar 25, 2011 6:29 am
Cliff
Cliff
I didn't answer your question right the first time. I used a 5/16" rabbeting bit to notch the sides out and then used a pattern bit and took out the rest of the material. I learned that from aggie 79 and it really turned out well.
my camera sucks. I really need to get a new one. :lol:
LDK
Postby Jst83 » Fri Mar 25, 2011 10:56 am
LDK wrote:I'm close to being done with the galleyImage
Nice galley :thumbsup: Is that stained wood you did, if so what kind of wood and stain. I really like the color
Jst83
Images: 215
