Fly Away Doors
Fly Away Doors
Postby Jim Edgerly » Sun Mar 27, 2011 4:45 pm
OK guys, time to provide me with more input. How to you keep your doors from flying away in a stiff wind? I don't want to open my door only to have a heavy wind take it away from me and slam it into the side of my TD...especially if the crank out window is half way open (i.e. serious damage to TD side and window). I have considered using a safety chain similar to the kind you see on aluminum storm doors on your house so that the door can only open just slightly past 90 degrees. How does everybody else ensure you don't have a run-a-way door situation?
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Jim Edgerly
Images: 142
Postby 48Rob » Sun Mar 27, 2011 5:40 pm
Hi Jim,
I use a "safety chain" of sorts on mine.
It is a piece of heavy canvas strapping.
It attaches to the door, and door jamb, or wall and prevents the door from going too far.
On other trailers I have used leather straps.
Rob
48Rob
Postby ERV » Sun Mar 27, 2011 6:04 pm
Jim
I do the same, a strap and I also put a small handle on it so it doesn't get away from me. When we want to keep it open there is a latch on the side to hold it open.
ERV & JAN
Medina, Ohio
ERV
Images: 90
Postby madjack » Sun Mar 27, 2011 7:27 pm
...same here...I cut a couple of nylon straps off of a set of ratcheting tie downs and using a trim washer screwed it to the door and inside wall...works great and when we wanna leave the door open for show and tell we hook a bungee to the door and trailer frame, pulling against the straps.............
madjack 8)
chain
Postby mvperini » Sun Mar 27, 2011 8:03 pm
I use a stainless steel chain with a clear rubber cover, was a chain on one of the doors on a piece of equipment i used work on, junking out the equipment i will check and see if we have anymore
Mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby Woodbutcher » Sun Mar 27, 2011 8:21 pm
I got 2 sets of seat belts at a junk yard. Then I screwed through a metal strap to hold both ends in place. I can easily remove my doors if I need to by unbuckling the belt. Works well, it's strong and cheap.
Woodbutcher
Postby Big Dan » Sun Mar 27, 2011 8:45 pm
I make myself aware of the wind conditions and I'm careful when opening the door. A friend pulled into a gastation on a real windy day in his 36ft motorhome and instead of parking nose to the wind. He parked the other way and the driverdoor flew open so hard it broke the windshield.Spendy mistake.
"Happiness is only real when shared" Alexander Supertramp
Big Dan
any more pictures
Postby Jim Edgerly » Mon Mar 28, 2011 6:08 am
Thank you everybody. Pictures are always most welcomed and I appreciate them...I'm a visual sorta of guy (if any of you've checked my build journal you'll know what I mean).
Jim Edgerly
Images: 142
Postby aggie79 » Mon Mar 28, 2011 9:53 am
Jim,
Thanks for asking the question. I've found out about something I need to do to my teardrop.
Take care,
