Deryk's lil Vardo
Postby Deryk the Pirate » Fri Apr 08, 2011 1:17 pm
Thanks!
I took it to get weighed as it is with the windows temporarily screwed in place 620lbs. So Im happy its in the range I calculated it would be.
Wasnt bad driving, although I felt the drag a little as I moved up to 55mph. I only did a short 4 mile ride cause it was drizzling which turned to rain. Hubs were cool to the touch... I might think of an air deflector or something. Otherwise it pulled fine.
Deryk the Pirate
Images: 158
Postby Laredo » Sat Apr 09, 2011 11:12 am
The paint job will make all the difference in the world, Cap'n...............
Laredo
Postby Deryk the Pirate » Sun Apr 10, 2011 3:33 pm
Laredo wrote:The paint job will make all the difference in the world, Cap'n...............
Image Still more to paint and trim but Im in agreement with you!
Deryk the Pirate
Images: 158
Postby Laredo » Mon Apr 11, 2011 9:28 pm
Now, ye need a bowsprit!
Laredo
Postby Steve_Cox » Tue Apr 12, 2011 4:20 am
Laredo wrote:Now, ye need a bowsprit!
:yes: It would be a good place to store the anchor while underway.
Steve_Cox
Images: 196
Postby StandUpGuy » Tue Apr 12, 2011 6:57 am
Its pretty tall how are you going to get in? I think you need some sort of plank!
StandUpGuy
Images: 52
Postby Deryk the Pirate » Tue Apr 12, 2011 9:15 am
My friend and his daughter(who is also a carpenter) built some nice black walnut rough huned benches...Im thinkin of building one about 10" tall as a step and as something to sit on inside. My plan is on the right of the door across the front of the vardo Im going to make a counter top with storage under it so I have a flat surface to put stuff down on (laptop lol) and the stool to sit on. I want to hide a porta pottie under it if Im campin somewhere without facilities or the weather is bad and Im feelin lazy lol.
Deryk the Pirate
Images: 158
Nice
Postby cyfan72 » Wed Apr 13, 2011 10:37 pm
Very nice build! Love the style and proportions. Great job so far :applause:
cyfan72
Images: 65
Postby Deryk the Pirate » Thu Apr 14, 2011 10:06 am
Thanks! Im lookin forward to useing it this summer...alot lol. Like a 2nd home!
Deryk the Pirate
Images: 158
Postby bobhenry » Thu Apr 14, 2011 10:29 am
Deryk the Pirate wrote:My friend and his daughter(who is also a carpenter) built some nice black walnut rough huned benches...Im thinkin of building one about 10" tall as a step and as something to sit on inside. My plan is on the right of the door across the front of the vardo Im going to make a counter top with storage under it so I have a flat surface to put stuff down on (laptop lol) and the stool to sit on. I want to hide a porta pottie under it if Im campin somewhere without facilities or the weather is bad and Im feelin lazy lol.
I have the same problem with the barn and I just built some simple steps
They may look large and kinda clunky but when your arms are full and you are loading up they feel great underfoot
They are the last thing in and the 1st thing out !
Here is a bit of a glimps of how they are made I couldn't find a full picture of them :x
Postby Deryk the Pirate » Fri Apr 15, 2011 9:41 am
Thanks Bob, yeah a nice solid step is important... fallin on your ass in front of people is never a good thing (unless they are drunker then you lol)
Deryk the Pirate
Images: 158
Postby Deryk the Pirate » Fri Apr 15, 2011 10:36 pm
Didnt get as much accomplished as I planned and rain is moving in.
I got the door together. Im not goin with the piano hinge, gettin something a little stronger. Image
Trim piece is shot and glued need to sand it tomorrow and start painting it... Image
Back window Image and new window frame minus paint and plexiglass Image
The back window is going to swing up so I can slide a 5000 btu air conditioner in it.
I went with the 45ml EPDM rubber roof. Had to order the correct adhesive http://www.bestmaterials.com/detail.aspx?ID=16077 ( Thanks Steve!)
So next week the rubber roof will go on, then I can start insulating the inside and run ac and dc wires...
Deryk the Pirate
Images: 158
Postby bve » Fri Apr 15, 2011 10:43 pm
Right on Deryk, that's coming along quite nicely.
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby Deryk the Pirate » Fri Apr 15, 2011 11:18 pm
Thanks Burke, but it feels like I should have gotten more done lol. The rain is now for saturday night so I can get some work done (prepping for painting the door and trim and the window frame... cant wait to have it closed up so I can start runnin wires then insulate it.
then play time starts lol
Deryk the Pirate
Images: 158
Postby chorizon » Sat Apr 16, 2011 8:20 pm
Looks like you've done an awesome job, Deryk.
You definitely have me thinking about my next build! :thumbsup:
What kind of hinges were you thinking about vs. the piano hinge?
chorizon
Images: 94
