StandUpGuy's TTT (Not-a-RV)
Postby StandUpGuy » Sat Apr 23, 2011 7:26 am
myoung wrote:
StandUpGuy wrote:Oh the dimensions. The width to the outside of the exterior walls is 62" From rear to front of cabin is 118". The height from floor to main roof exterior is 51" and the pop up is not yet detirmined in thickness. Probably another 3 to 4".
If you are trying to keep the height low enough to clear a standard garage door, then you could have more interior height. My TTT has 60 inches on the interior at the lowest points around the perimeter of the popup, about 4 more inches inside the popup, and 16 inches more with the popup fully extended at its highest point. If you make the sides of the popup out of rip stop nylon or similar cloth, then you can raise the popup to different heights as needed, reduce weight, and gain interior height inside the popup enclosure. If you are interested in this approach, have a look at my build thread.
Good luck, good building.
My mistake. I meant to say 61". On the elevation you can see a divide between the white and the gray below. The upper white section is a 48" x 96" sheet. It is a pretty efficient layout for materials.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Apr 23, 2011 7:31 am
Yes originally I had hard wall hinged pop up sides, but later I decided it was a potential headache. Water leaking, weight and general complication made me decide on fabric sides. Potentially it could be nice to have large mesh windows in it with roll up ffabric window covers, like a tent. I figured that the hard sides of this kind of pop up would pretty much weigh an entire sheet of 3/4" plywood so it is a pretty big weight savings.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Apr 23, 2011 12:21 pm
some framing of the front floor is complete.
By justoneman at 2011-04-23
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Apr 23, 2011 12:23 pm
This gives a good idea of the bathroom size. The pan will be a little bigger than I thought because I can push the toilet back a little further than I thought.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Apr 23, 2011 12:25 pm
I am sure all think I am obsessed with toilets by now. :? Here the verticle sticks represent the corners of the bathroom walls.
StandUpGuy
Images: 52
Postby starleen2 » Sat Apr 23, 2011 3:51 pm
Get the throne room just right :thumbsup: - then all else will fall into place!
starleen2
5th Teardrop Club
Postby Miriam C. » Sat Apr 23, 2011 4:15 pm
starleen2 wrote:Get the throne room just right :thumbsup: - then all else will fall into place!
+1 If you are gonna do it, then do it right the first time. Places where there are water sources need a little extra time...
Postby Deryk the Pirate » Sat Apr 23, 2011 9:05 pm
Its all about the head...er' toilet ;)
Deryk the Pirate
Images: 158
Postby StandUpGuy » Sat Apr 23, 2011 9:20 pm
I got my toilet (head) off of Craigslist for 50 bucks. Score! I got the RV sink for 15. I am doing it on the cheap.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Apr 23, 2011 9:24 pm
I used to have a 27 ft Cornado sloop on Lake Michigan. http://sailboatdata.com/VIEWRECORD.ASP?CLASS_ID=607 Man I miss that boat. You have a boat right? What do you have?
StandUpGuy
Images: 52
Postby StandUpGuy » Thu Apr 28, 2011 3:35 pm
Possible paint scheme:
By justoneman at 2011-04-28
StandUpGuy
Images: 52
Postby StandUpGuy » Thu Apr 28, 2011 6:44 pm
I have done some framing for the drop down shower pan in the bathroom.
StandUpGuy
Images: 52
Postby StandUpGuy » Thu Apr 28, 2011 6:46 pm
And some further framming of the front extension area. I am almost ready to lay down the decking.
StandUpGuy
Images: 52
Postby StandUpGuy » Thu Apr 28, 2011 6:51 pm
I am a little concerned as I have gone through some pains to keep things very light but the toilet I picked up on Craig's List is of a high quality with a china bowl. Very nice deal but it is not a light weight toilet in the least.
Not only is it heavy but I was chose to move the position of it to the absolute rear as a result of the trailer frame location. this has pushed this weight even further from the axle.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 01, 2011 10:36 am
Here is my shower pan sequence from this morning:
By justoneman at 2011-05-01
StandUpGuy
Images: 52
Users browsing this forum: Bing [Bot] and 10 guests
