Thanks!
Cary Winch wrote:That is pretty much the idea, there needs to be some support or after the hole in the aluminum is cut it will flare out. Though making it 3/4" thick there might not be the solution. That style of gasket is very common but not for thick wall like Rob used. 3/16" is more likely what you will find. That is what we used on the Raindrop, go to this page and look at pictures of it and you will see how we made a framed opening inside to allow for this:
http://tinycamper.com/topsecret
Pictures 22-26 kind of show the inside and picture 4 shows the outside of a window.
Cary
48Rob wrote: Can you tell I'm not a Volkswagen man![]()
Rob
MikeDrz wrote:the beetle came to the US in 1949, was first made in 1945 in germany.
PaulC wrote:MikeDrz wrote:the beetle came to the US in 1949, was first made in 1945 in germany.
I may be wrong here but my history book shows the first "peoples car"(VW) was built in the 30's. As a side note, it was originally designed by Ferdinand Porsche. Same bloke who designed and built Porsche cars.
Cheers
Paul
