Trolley top mk 2....., Wanda
Re: trolley top windows
Postby jackdaw » Fri May 06, 2011 4:07 pm
danlott wrote:I debated the number of windows on my trolley top. I think 4 on each side looks best. Three does not look like enough and five seems like to much.
Where did you find the windows? Are they the screw-in access plates? If so how do you plan on using them? Are you replacing the screw-in plates with something else?
I still have not decided how I will be doing my trolley top windows, so I am very interested in how you do yours.
Dan
Thanks for your input Dan :thumbsup:
I found the windows on ebay..they were very reasonable (cheep :D) They're quite chunky , check out this link
The size is 4 7/8" outside diameter, 3 7/8" rebate, and 3 5/8" inside diameter.
They do a larger version too.
I've cut some perspex with a hole saw that sits nicely in the rebate. I think I'll silicone the perspex in place and make up a gaskit to fill the rebate. I'll fix the windows with polyurethane sealer and 6 screws in each. I've got a 3 1/2 hole saw, It's about the right size to cut the holes.... If I wiggle it a little.
Cheers Dave
jackdaw
Images: 124
Postby GuyllFyre » Fri May 06, 2011 4:35 pm
The four per side look nice to me.
Things I have for sale on craigslist:
http://albany.craigslist.org/search/?ar ... catAbb=sss
Things I have for sale on eBay:
http://www.ebay.com/sch/merchant/seansmith
GuyllFyre
Postby High Desert » Fri May 06, 2011 8:21 pm
I think the 4 have a nice balance too Dave.
With the port holestyle trim rings on all the windows it somehow reminds me of the Nautilus from 20,000 Leagues Under the Sea... :thinking:
Shaun
High Desert
Images: 27
Postby Woodstramp » Sat May 07, 2011 12:00 am
That looks amazing. My hat's off to you Dave. Show it off....it's special.
Woodstramp
Postby warbird » Sat May 07, 2011 2:06 pm
Just got back from Daves, Four holes it is then!! :) Its looking good too! Had a great day buddy, gonna get on with the repairs to my 'Little Guy' tomorrow, cutting some new wood! :o
Its not always true that size matters!
warbird
Postby jackdaw » Sat May 07, 2011 4:08 pm
Thanks for all the replies ....Initially I thought 5.... and Barry who's buying the trailer thought 4..... His wife Jeanette said it didn't matter on how many were used because it would look great anyway. :lol: :lol:
As warbird said..... four it is then. 8) 8)
We've had a most unusual spell of dry weather over here. I can't remember how many weeks ago it was when we last saw rain. Usually April is wet, but not this year :) We had a little rain this morning, but it soon dried out.....until we cut the last of the eight windows out......not long after the skys opened and it hasn't stopped yet......The cover's back over the trailer.... I'm sure we'll get the windows fitted tomorrow :D :D
Thanks again for helping us out :thumbsup: :thumbsup:
Geoff we had a great day... as usual.. Thanks for coming over, and lending a hand....We'll get your little guy ready for the end of the month, as long as the rot doesn't go to far forward :worship:
ATB Dave
jackdaw
Images: 124
Postby warbird » Sat May 07, 2011 4:32 pm
You mean this??
Image :shock:
or this??
Image :(
or maybe even this???
Image :cry:
warbird
window link
Postby danlott » Sat May 07, 2011 7:42 pm
Dave,
Thank you for the link to the rings you are using for your porthole windows. Make sure to take some good pictures of the installation. I might be able to use them for my build.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Re: window link
Postby jackdaw » Sun May 08, 2011 5:09 pm
danlott wrote:Dave,
Dan
I fitted them today, after a lot of preparation.... but they're now in.
Just for Dan, I took a few extra shots, that may help to show how they're fitted.
I have a cheap hole saw set, that has large cutters.
I cut a hole the size I wanted the perspex in an off cut of ply. Then I could remove the pilot bit, and use the off cut as a guide to cut the windows out.
I spent the yesterday evening covering the perspex with limo black film so you can see out, but not in. and silicond the perspex into the frames, so they were all ready to go today.
Here's the holes saws I used to cut out the side of the trolley top and perspex
I thought it might be a good idea to mount the rings on rubber gaskits instead of sealing them on with polyurethane sealer. At least they could be easily removed to re-polish the trolley top. I used pond liner to cut all eight gaskits
This next shot shows one of the rings on the left, and then the difference in sizes of the side cut out, on top of a piece of perspex, on top of a rubber gaskit. On the right is one of the rings with the tinted perspex set in place.
This is what the inside looks like
Each hole was marked, and pilot holes drilled before screwing the rings in place.
I gave the area a little going over with some more polish, and screwed the windows in place.
I polished the hatch up a bit more too :D :D
Just the sliding window to fit in the rear of the trolley top to go. I've made it up, and going to fit the tint and varnish before it goes in.
Cheers , Dave
jackdaw
Images: 124
window install
Postby danlott » Sun May 08, 2011 7:26 pm
Thank you for the extra photo's Dave. I think I will contact the seller of the rings and see about getting some shipped over.
Dan
danlott
Images: 264
Postby droid_ca » Sun May 08, 2011 8:30 pm
I must say you do amazing work and your photos make it look easy thank you for such a good guide
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby jackdaw » Sat May 21, 2011 3:02 am
Thanks gents...I'm guessing its time for another update :D
Last weekend our good friends Barry and Jeanette came for a visit to see how the trailers's coming along , and to help paint the chassis.
After a few coffee's and cake, we got stuck into the trailer. the plan was to paint the chassis, after demounting the trailer, and stripping the old paint off.
Many hand make light work ... Luckily Warbird called in to lend a hand too.
Stripped down chassis
Red oxide going on
Almost done with a first coat
Back to black
remounted
Great day of chin-wagging and getting it done :D :D
I wouldn't let them leave without checking out the trailer on the back of their Deli
The new tyre came in the post, so our local tyre fitters swapped the tyres over to the right wheels....
Then after fitting some trim along the bottom of the trailer, and touching up the chassis with black paint. I fitted the first mudguard
Then the same for the other side :D :D
Then the handles were fitted to the back of the trailer. One for the hatch, and then one under each light...to give them a bit of protection ans for a bit of styling. The number plate has been put on, but I'm waiting for the led numberplate bolt before it's properly fitted. I only had time to make up one of the triangle reflector brackets....I hope to get the other one done tomorrow.
I'm ready to bolt the trailer down, and get the road lights wired up if the led's turn up tomorrow...maybe finish the rear window if all goes well.
Heres a few more shot's because we like photos :D :D
Also started on the cupboard doors....the first one's done
jackdaw
Images: 124
Postby Wolfgang92025 » Sat May 21, 2011 9:53 am
Dave,
Very nice :thumbsup: :thumbsup: :thumbsup:
Thanks for all the :pictures:
Wolfgang
Wolfgang92025
Images: 660
Postby jackdaw » Sat May 21, 2011 2:37 pm
Thank you Wolfgang..
We've been busy again :D :D
Today Rosie decorated the galley....I'm not sure what Barry and Jeanette will think of it as it isn't the neutral colour that we talked about last weekend :oops: :oops:
I like it ..and i hope they do to.
The number plate lights turned up in the post, so I can wire them up tomorrow. All the internal window frames have been removed and stained , the windows have been tinted with limo black tint. The rear window has been made up, stained, and the perspex tinted, ready for fitting tomorrow. The other triangle's been fitted :D :D
We've gone from this
To this.....
Should we keep the fish in the galley, or loose them .....What do you think ?
jackdaw
Images: 124
Postby droid_ca » Sat May 21, 2011 3:17 pm
I'm really liking your build :applause: :applause: :applause: :applause:
where did you get your tail lights I like them?
Awesome job on building this trailer
“Fide Canem”
droid_ca
Images: 176
