Trailer lights
Trailer lights
Postby Deryk the Pirate » Thu May 05, 2011 8:51 am
Ok next weekend Im plannin on bringin my vardo on its first real trip (bringin it home) Now when i took it for a test ride I used the magnetic break light but I want to wire it up corectly. I know I need the 2 break lights that came with it in the back, but do I need the side amber lights? Do I need a license plate light?
thanks
deryk
Deryk the Pirate
Images: 158
Postby fromeo » Thu May 05, 2011 9:11 am
fromeo
Postby Deryk the Pirate » Thu May 05, 2011 11:33 pm
Thanks Frank... this should be a sticky
Deryk the Pirate
Images: 158
Postby bobhenry » Fri May 06, 2011 6:26 am
I went with the more lights the better theory.........
I have redundent stops and tails (2 full sets)
and 4 clearance lights on each side on the teardrop.
The barn has the low mounted stock tail lights and that made me nervous so I mounted a high stop lamp as well. The barn also has 3 clearance lights each side. If a guy (or gal) swings out to pass the guy behind me I want them to know I am towing and not think its a landing spot behind my truck.
Postby bobhenry » Fri May 06, 2011 7:22 am
Somewhere on here it has been discussed wiring the center clearance as a turn indicator also. You have seen this on semi trailers mid way under the bed.
By using a two bulb clearance light the wires can be seperated by cutting one and rewiring it to the turn indicator circuit on its respective side. One bulb will remain as a clearance the second will announce your intentions to turn to motorists that can see the side of your trailer.
Postby Deryk the Pirate » Fri May 06, 2011 10:58 pm
Bob that is a really good idea, anything not to get hit lol
Deryk the Pirate
Images: 158
Postby atahoekid » Sat May 07, 2011 1:30 am
You might want to check your state's motor vehicle website. Here in Nevada, they have a document that describes all the requirements for trailers. It talks mainly about brakes. reflectors and lights and though there is probably a national standard, your state might have something different.
Mel
atahoekid
Images: 158
Postby Dale M. » Sat May 07, 2011 9:22 am
Most states just echo the NTSB site recommendation for lighting....
Dale
Dale M.
Images: 18
Users browsing this forum: Bing [Bot] and 6 guests
