10' Standie Foamie ... on hold
Postby Ratkity » Sat May 14, 2011 7:11 pm
I roughed up the foam on the cover (threatened it with bodily harm, broken arms, etc) .. hehe. I was just having too much fun rounding corners and making pink foam dust!
Hugs,
Ratkity
Ratkity
Postby Wolffarmer » Sat May 14, 2011 8:18 pm
Mike great progress.
What grit of sand paper did you use?
Also I was thinking of a sticky for Joinery issues/topics. Such has your windows and doors. How to fasten to the floor. What people have used and their experience with it.
Just a thought
Randy
Wolffarmer
Images: 309
Postby mikeschn » Sun May 15, 2011 5:30 am
Wolffarmer wrote:Mike great progress.
Just a thought
Randy
Randy,
I used 80 grit sanding discs. Very aggressive, you have to keep the sander moving and use a very light touch, or you'll put a deep gouge in the foam faster than you can say, "What the heck!".
I am going to try a test today on two small samples, to see if there is a significant difference between sanded and un-sanded.
Postby GPW » Sun May 15, 2011 5:48 am
Mike , in my "test", on the un-sanded foam , the cloth lifted fairly easy , on the sanded foam when I tore the strips off , some of the foam came with it .. :o
Postby stomperxj » Mon May 16, 2011 9:58 am
Great progress Mike. I will be watching with great interest. I have been designing a foamie/wood hybrid myself for the next build.
Any reason you are choosing to cover it in canvas rather than fiberglass cloth other than cost reasons?
Jess
stomperxj
Postby Todah Tear » Mon May 16, 2011 4:33 pm
swampjeep wrote:...I hear if you dampen the canvas, and throw it in the drier for a few minutes, it will take the wrinckles out... but that's just what I've heard. :D
It does. I did that and I even ran an iron over mine after the dryer.
Todah
Todah Tear
Images: 282
Postby pat g » Mon May 16, 2011 8:30 pm
Looking good Mike!
Pat G
pat g
Images: 122
Postby mikeschn » Thu May 19, 2011 5:07 pm
Well, the temps were above freezing today. Actually they were slightly over 70 when I went outside this evening, so I decided to play with the foamie. I recently purchased some vinyl spackling for this purpose.
So I went outside and put some spackling on the first side. While it was drying the rain moved in. So I pushed it back in the garage. I guess I am done for today.
I sure hope we have a decent weekend for building! :?
Postby GPW » Thu May 19, 2011 5:14 pm
I hope you do to !!! :thumbsup:
Postby eaglesdare » Thu May 19, 2011 5:53 pm
ditto what the bear says.
please tell me what this vinyl spackling is?
Louella
May the foam be with you.
eaglesdare
Postby GPW » Thu May 19, 2011 6:21 pm
Like wood filler/putty only white ... sorta' ...used on drywall
Postby mikeschn » Thu May 19, 2011 6:24 pm
I bought mine at the hardware store. It look like this sitting on the shelf...
Postby GPW » Thu May 19, 2011 7:08 pm
Same as I used Mike ... worked fine , made a chalky mess when sanded... :o
Postby eaglesdare » Thu May 19, 2011 7:13 pm
does this stuff dry hard? is it just for the purpose of filling in holes/gaps? it won't hold 2 pieces together correct? is it used pretty much just to make things flat?
do you have to sand it?
sorry for going back to asking these stupid questions.
Louella
eaglesdare
Postby GPW » Fri May 20, 2011 6:00 am
Eagle , it's just a "filler" for dents and such .. not a glue ... Say you're hanging a picture on the wall , and the hammer slips and you put a dent in the sheetrock ... spackle fixes that ... :thumbsup:
Yes you trowel it on , let it dry and sand it flush with the surface ... "makes things Flat " ... ;) Great for those little dents and scratches that seem to get into foam sheets ... You just have to let it dry Thoroughly , before you sand it ...
