Conedodger wrote:In joints its all to do with area and having no movement on any right angle joint. Bonds with large surface areas are more difficult to break.
Titebond II has amazing strength when used on materials its designed for and remember foam is not one of those listed.
Wobbly Wheels wrote:Thanks, GPW
Breaking how, oz ?
The foam is really just acting as a mold for the glass. That joint will be tabbed inside and out and sheathed on the outside over the tabbing. When it's done, it will be a monocoque structure with all the strength and rigidity that suggests. Unless I've overlooked something ?
EDIT: I think I know what you mean, but the 'lip' is just a chamfered ring to make sure that the roof drops down squarely and 'locks' into its recess to transmit highway loads through the whole shell and mitigate the effect of the gap in the shell from the roof cutout.
swampjeep wrote:Conedodger wrote:In joints its all to do with area and having no movement on any right angle joint. Bonds with large surface areas are more difficult to break.
wouldn't the "joint" you keep talking about actually be held together by the cloth to wood, where it wraps around the underside of the trailer? the cloth is pourous, and the glue should bond the cloth to wood with "amazing strength" then... right?
Wobbly Wheels wrote:Gotcha, oz - I can see it would clearly be a probably if the joint was cantilevered outboard of the frame rails. My trailer frame is a bit of a different beast: it's like a boat trailer with two rails rather than a grid for the deck, so a failure there is certainly possible between that joint and the rail.
I haven't looked into how to frame the floor yet, but I've assumed it'll be something like a series of transverse 1X2s with foam between, a ply panel on the inside (top) and glass and undercoating underneath (prob Rhino liner or equiv). Regardless, I'll definitely need to make sure the floor is framed well, so thanks for bringing it up. I could use a sheet of 3/4 ply if it weren't for the weight...
I'm going to start a build thread pretty soon after seeing GPW's off-frame build. Mine's a bit bigger, but I should be able to build it the same way and keep using the tent trailer through the summer.
