I'm trying to determine how to mount the PV panel to the roof of the TD.
The roof (and sides for that matter) of my TD are made of a sandwich of 1/8" ABS with Al skin. The roof has 1" metal spars, however, I've covered up all but two of them with inside cabinetry. A couple of questions for the experts:
1- How would you fabricate mounts for the panel given the thin skin of my TD?
2- One option would be to attach risers to the sides of the trailer and then run rails across the entire roof.
3- The PV panel will be fixed. Spots on the TD where the panel will fit are fore and aft of the vent which are sloped. My intuition is to mount the panel flat and not follow the curves of the TD. Would this look silly or catch too much wind when in tow?
Cheers,
Ron
