10' Standie Foamie ... on hold
Postby Wolffarmer » Sat Jun 04, 2011 7:29 pm
ARKPAT wrote:I wonder if Dove-tail jointing in main body panels if it would work in making a strong and one-piece type construction of a shell.
Pat
Dove joints would look great and add a lot of gluing surface. But thinking about it wouldn't a box type of joint be about as good and probably easier to do?
Randy
Wolffarmer
Images: 309
Postby whitefishpoint » Sat Jun 04, 2011 7:29 pm
This foamie technique is amazing! :) Great stuff!
Steve_Cox wrote:Looks to me we could have some serious compound curves and radii built in foam sheet and glued block, shaped with a power hand planer, and finished with an orbital sander.
Had I known about this last year, it could have been an option for me instead of making a model, mould, and fiberglass corner caps! Dooh!
whitefishpoint
Postby RAYVILLIAN » Sat Jun 04, 2011 7:51 pm
It's looking great Mike. I thought of trying a foamy hatch on the new trailer but than chickened out. That was just before all the new foamy stuff started so I'm back to thinking I need to build a new hatch with foam. I still like the wood look on the inside of the hatch walls so I'm not sure how much weight I'd really save.
GAry
PS I'm always here just don't talk much some times. Gotta go slump some glass.
111961Image
RAYVILLIAN
Images: 109
Postby whitefishpoint » Sat Jun 04, 2011 8:06 pm
Hey Mike, After this technique is perfected, the next step should be.....
Just drop in some water and watch your trailer grow before your eyes. :lol:
whitefishpoint
Postby eaglesdare » Sat Jun 04, 2011 8:30 pm
wow, that cut is so clean. i seriously would not have expected that. but it looks good. hmm, maybe i won't be so chicken about cutting my outlet out. :thinking:
everything is looking good on your build. love watching this one come together.
Louella
May the foam be with you.
eaglesdare
Postby Wolffarmer » Sat Jun 04, 2011 9:20 pm
Mike, when you cut that foam with canvas/TB2, what type of blade did you use?
Just thinking about using saw I envisioned the threads being pulled out. Sort of like drilling through carpet, that just does not work.
Thanks
Randy
Wolffarmer
Images: 309
Postby mikeschn » Sun Jun 05, 2011 3:49 am
RAYVILLIAN wrote:
PS Gotta go slump some glass.
What are you making? I didn't realize you had a kiln!
Postby GPW » Sun Jun 05, 2011 7:37 am
Mike , it's looking SUPER !!! Thanks for the after dinner pics ... 8) :thumbsup:
Postby mikeschn » Sun Jun 05, 2011 7:51 am
Since I have a piece of canvas covered scrap, I figured I'd try putting some fiberglass resin on part of it to see if it hardens...
I notice that it's melting the foam!
:shock:
Postby GPW » Sun Jun 05, 2011 8:05 am
Well, at least you know the canvas will stick well .... :lol: Must be polyester resin huh ??? Epoxy won't melt it AFAIK...
Postby mikeschn » Sun Jun 05, 2011 4:33 pm
It was a little bit of a shorter day on the foamie build, since I had to build a computer desk for my mom.
But the floor is coming along nicely... Here, you can see, the chassis and floor is almost done. Still have to do the wheel wells, and then flip it over and add reinforcements to the dropped floor. Then the black goo!
Just for fun, I dry fitted the walls again...
Here's an interior view...
And a profile view...
Postby GPW » Sun Jun 05, 2011 4:51 pm
WOW!!! Too COOL !!! 8) Looks really Roomy on the inside !!! :thumbsup:
Postby eaglesdare » Sun Jun 05, 2011 5:02 pm
ditto what gpw says. it looks great!
Louella
eaglesdare
Postby Conedodger » Sun Jun 05, 2011 5:50 pm
Mick:
Are the walls more solid now you have the "Keys"?
Conedodger
Postby mikeschn » Sun Jun 05, 2011 5:59 pm
Conedodger wrote:Mick:
Absolutely. The weight of the walls is resting on the floor, not on a few screws... :thumbsup:
Thanks for making me rethink the mounting...
