Electrical Question
Electrical Question
Postby john curtis » Mon Jun 13, 2011 9:06 pm
Was wondering if anyone can tell me if I need to instal a 30 amp. fuse at the battery when there is a 30 amp. fuse in the power center.
Thanks John
john curtis
Images: 141
Postby madjack » Mon Jun 13, 2011 9:29 pm
John, the 30A fuse at the power center is to protect it and anything connected to it...the use of a 30A fuse at the battery is to protect the wiring from the battery to the power center...it's use is up to you...................
madjack 8)
Re: Electrical Question
Postby dh » Mon Jun 13, 2011 9:31 pm
Yes.
If there is a short to ground from the wire running from battery posative terminal to power center, it will blow the power center fuse, but if the battery is not fused as well, you will still short the battery posative terminal to ground.
dh
EL Question
Postby john curtis » Mon Jun 13, 2011 9:34 pm
Thanks for the info everyone, I will be getting a 30 amp in-line.Better safe than sorry.
Thanks again John
john curtis
Images: 141
Postby Dale M. » Tue Jun 14, 2011 9:18 am
dh wrote:Yes.
If there is a short to ground from the wire running from battery posative terminal to power center, it will blow the power center fuse, .
I think you missed it on that statement....
IF fuse is down steam of short it does no good....
Dale
Dale M.
Images: 18
Postby pete42 » Tue Jun 14, 2011 9:06 pm
Simple answer a fuse or circuit breaker protects everything after it.
battery---fuse----wire----power center with fuses/circuit breakers---wire----switch---light
in this case the first fuse protects everything from battery to the power center.
the fuses/circuit breakers protect everything from power center to what every they feed lights, furnace, TV's ect.
by protecting everything after the fuses they also help protect the thing in front ex: a short without a fuse could cause the battery to explode.
add a fuse be safe.
pete
pete42
Postby dh » Wed Jun 15, 2011 1:45 am
The fuse is inside the power center, pretty hard short out upstream of that fuse. On the battery side you gotta get the fuse as close to the terminal as you can.
Dale M. wrote:
dh wrote:Yes.
Dale
dh
Postby TheresaD » Wed Jun 15, 2011 10:03 pm
:stompspam:
All The Best,
Theresa D.
Tearjerkers Great North Woods Chapter Director
68 Sprite 400
47 KIT Companion
146633
TheresaD
Images: 54
Postby Dale M. » Wed Jun 15, 2011 10:05 pm
SPAMMER........... Webmaster you need to dump this guy.....
Dale
Dale M.
Images: 18
