Postby Wolffarmer » Wed Jun 15, 2011 9:36 am
My thinking was to let the bear have the beer. then marinated bear would be on the menu
Wolffarmer
Images: 309
Postby GPW » Wed Jun 15, 2011 9:51 am
Let the Bear have the Beer ? :o I hope not to think so ... let the Bear get his own Beer... :lol:
Postby Conedodger » Wed Jun 15, 2011 10:11 am
Drink the Beer, when done you may well be Bare, then run away from the Bear
Conedodger
Postby GPW » Wed Jun 15, 2011 10:23 am
Figuring with that much Beer , we could supply a large gathering ...or one drunken Cajun ... :o The Bear might not like rowdy crowds... unless some fool has fed them Beer previously ... :shock: :roll: :lol: Nothing worse than a Bear with a habit eh ... :R
Postby Wolffarmer » Wed Jun 15, 2011 11:57 am
I don't need beer to get bare. Now that might scare off a bear.
:oops:
Randy
Wolffarmer
Images: 309
Postby GPW » Wed Jun 15, 2011 12:10 pm
OK, Now were getting Silly !!! :roll: I know , I started it , but creeped out Eagle so much she's speechless... :o
Postby Wolffarmer » Wed Jun 15, 2011 1:56 pm
Back on topic, did you use full strength or diluted?
I am loosing track of who did what
Randy
Wolffarmer
Images: 309
Postby GPW » Wed Jun 15, 2011 4:12 pm
Wolf , diluted mine to attach the canvas, Not quite 50/50 ... more glue than water... Then I went over the edges again with more of the same ... you can see in the pics how yellow the edges were.. that's the extra glue ... before I primed it I went over the seams with the household iron (no , not "Her's" ) .. The heat really smoothed the edges quite a bit ... Not really necessary , but it does work ... I was just trying to make mine as nice as I could , cause' I knew everybody would be watching ... Did NOT use the T2 over the canvas as a sealer , used Kilz (WB) for that , and only one coat ... next time I'll use two coats as the primer really smooths things out ... Had I used another coat , I could have obliterated the canvas texture... Had I the energy to sand it (block sand) I could have made it even smoother... Too HOT , Too OLD for all that ...
I still wonder if the Kilz alcohol based would work ??? Alcohol doesn't melt the foam ... and I think that stuff sands a little better...
Wolf , looks like we need a Master List of who's doing what ... Looks like there are several builds underway ... Maybe Eagle would know how to do that ???
Postby eaglesdare » Wed Jun 15, 2011 6:19 pm
i wasn't speechless, i just wasn't home. decided to take a walk along the beach. a perfect day for that.
i should have been working on the tear, but the walk was calling me.
i want to put in sliding doors in my, so how should i go about that? before you ask, yes please, pics would be nice. i would like to figure something out that i can rig up, instead of buying.
and i would hate to meet that bare drunk bear! he just might be a mean drunk. :lol:
i could put together something in a thread with all the links to our builds. how would that be? i will work on that tomorrow.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Wed Jun 15, 2011 8:42 pm
Walk on a cool beach sounds ideal about now !!!
Sliding doors ??? on what ??? Making them slide is easy ... cutting the slots is tough (not really ) Hubby have a table saw with a Dado blade... ? Could use Aluminum channels , but you'd have to buy those ... :roll:
A List of builds would be nice so we could all weigh in and keep others apprised of their progress ... Nothing fancy , just a place to check in ...
Kiddies out of school yet? ... good summer project would be teach them to build Foamies ... better than video games ... My Dad and I used to build things in the summers... learned some good skills for Later on ... Dad's 88 now ... doesn't build much any more ... :roll:
Postby eaglesdare » Thu Jun 16, 2011 7:02 am
on the "bunk bed" top i want to put sliding doors to the front inside the tear. that bunk bed area is going to be inside storage. clothes, towels, that sort of thing.
i want to build a wall to close off the back when the hatch is open. i might not use the whole flat top space, might keep some of it for the galley stuff.
maybe the easiest thing to do would be just buy a hinge.
Louella
eaglesdare
Postby GPW » Thu Jun 16, 2011 7:45 am
Does this help ? Image
Postby eaglesdare » Thu Jun 16, 2011 7:49 am
actually it does help! very much so. i could just route out the tracks in a foam piece. then just use the foam panels as the doors. i told you i am a visual ole gal. that would work!
now if only i could find a bit. i have found the routers, but not any bits.
Louella
eaglesdare
Postby GPW » Thu Jun 16, 2011 8:03 am
It may be better to use wood for the bases... You'll need one for the top and the bottom... Beeswax (or a crayon ) in the grooves helps with the sliding ...
Routers are pretty useless without a bit ... :roll: :lol: they are expensive too ... :o And then you need to make/use some type of guide to ensure straight cuts ... You could make the bases by gluing up strips , but you'd still need to cut them accurately ... Tool Time !!! ;)
Postby Wolffarmer » Thu Jun 16, 2011 8:18 am
Make the groves in the top twice as deep as the bottom. and the panel the size of the opening + the depth of the bottom groves. Well maybe a tiny bit less just to be sure they work. But I bet you already figured this out.
I have some 1/2 inch foam that would make nice doors.
Randy
Wolffarmer
Images: 309
Users browsing this forum: Bing [Bot], DrAlvarez, jgmahoney and 14 guests
