Seam sealing
Seam sealing
Postby pawp » Wed Jun 29, 2011 6:31 pm
Has anyone used automotive seam sealer for TD window and misc sealing?
pawp
Images: 20
Postby parnold » Wed Jun 29, 2011 7:13 pm
Most typical automotive seam sealers are meant to be painted. They do not harden 100% and will pick up and hold dirt etc. I used a two part, epoxy seam sealer to seal the entire bottom of my trailer between the walls and the metal frame of the trailer, and coated with undercoating.
An automotive seam sealer will be fine as long as you paint or coat it with something.
btw for my windows I used butyl tape and clear silicone.
parnold
Images: 302
Postby Shadow Catcher » Wed Jun 29, 2011 8:35 pm
Silicone caulk is what is most used for RV and while it does not harden neither does it grab dirt.
Postby emiller » Wed Jun 29, 2011 8:37 pm
I used this
emiller
Images: 157
