by Jim Edgerly » Wed Jul 20, 2011 4:36 pm
I just plan on using my bathroom scale. My tongue weight should be around 150 pounds, which seems to be in the 'sweet spot" for a bathroom scale. I'll just prop up a 2x4 between the tongue and the scale to keep the trailer level and the hitch at the right spot and it should be within a couple pounds or so of the actual weight...accounting for the scale being off in the couple pound range. Any way...it should be close enough. I will eventually get the whole trailer weighed at a truck stop when completed, but until then and to get it there a good guess will be close enough.
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
