S. Heisley wrote:urban5 wrote:I would go to a box store and have some 1 in gas pipe cut to fit. That would defiantly hold the weight. It is heavier, but wouldn't flex at all.
I thought about that one, too, but deleted my same suggestion because of the damage that metal pipe can do to a body, etc, if it falls.
urban5 wrote:S. Heisley wrote:urban5 wrote:I would go to a box store and have some 1 in gas pipe cut to fit. That would defiantly hold the weight. It is heavier, but wouldn't flex at all.
.....Hmmm well a 6' piece of 1 1/4" gas pipe will hold over 400lbs, a 1" isn't far behind it. I would be more concerned about the bracing failing than the pipe.
dh wrote:urban5 wrote:S. Heisley wrote:urban5 wrote:I would go to a box store and have some 1 in gas pipe cut to fit. That would defiantly hold the weight. It is heavier, but wouldn't flex at all.
My exact thoughts are in RED
Also, what if you knock your head on it when you sit up? What happens when SHE hits her face on it while tossing and turning in the night? A pad may be wrapped around it before the fabric gets sewn on, but consider safety first.
As did I. I realize, as a noob, my opinions are suspect until I have paid my dues. No problem there, I belong to a number of groups and am aware of the pecking orders. I gave a solution that is cheap, easy, will not sag, will not break, will not fall, will not fail, does not require heavy pipe, straps, additional support gizmos or a degree in engineering and was, evidently, ignored. I call it, "Ignoring the obvious in search of the obscure". I have learned, over the years building motorcycles, hot rods, furniture etc, that the KISS principle works every time, at least for me.urban5 wrote:. He asked for an opinion on something that would not fail, so I gave him one. To each his own.
I think you need to explain your idea better. Drawings or a photo are always good.CarlLaFong wrote:As did I. I realize, as a noob, my opinions are suspect until I have paid my dues. No problem there, I belong to a number of groups and am aware of the pecking orders. I gave a solution that is cheap, easy, will not sag, will not break, will not fall, will not fail, does not require heavy pipe, straps, additional support gizmos or a degree in engineering and was, evidently, ignored. I call it, "Ignoring the obvious in search of the obscure". I have learned, over the years building motorcycles, hot rods, furniture etc, that the KISS principle works every time, at least for me.urban5 wrote:. He asked for an opinion on something that would not fail, so I gave him one. To each his own.
Users browsing this forum: Bing [Bot] and 5 guests
