We want to build a TTT for use in the winter.
We will be traveling/living out of the TTT for three months this winter.
We want it to be as light as possible given the size.
We want it to be as cheap as possible
Our frame is 7x10, here's our original picture, however we added a stringer from the front to back of the frame for stability, but basiclly this is it
Our goal for the interior is to get it something like the T@B, here's our layout
Our profile will be something like this:
We are building a subfloor for insulation, and are using 1/2" plywood for the bottom, a stick frame(I think it's 3/4x 2 maybe?) to stick the insulation into and will cover it with a layer of plywood on top. So, question #1 what thickness should we use for the top layer of the plywood? The frame will follow the shape of the trailer, so it should be pretty well supported. Can we use 1/2" for this?
Question #2 We are planning on building the walls with a sandwich construction method, using 1x1's as the supports. If we include enough supports can we use 1/8" plywood for the skins or will they be too flimsy?
Question #3 We plan on putting some cabinets in the kitchen area above the counter, do we have to re-enforce the frame beyond the plywood/spars? Or would the overall construction be strong enough to support the weight of the cabinets?
Question #4 We ski, a lot, the teardrop will probably be getting significant amounts snow accumulating on the roof throughout the winter. We'll try to clear the roof off if we are in the trailer, but if we are out skiing and it's dumping snow we aren't going to come in from skiing to clear off the roof. Will our general design be enough to support the weight of snow on the roof? Should we put a pole inside of the TTT for extra support?
That's all for questions right now, thanks so much for your help.
-Ashley(and Dave)
