My version of back hatch supports
Postby CliffinGA » Tue Aug 23, 2011 9:15 pm
chartle said
Yea but that wouldn't make for slick finish.
and hey another Cliff, you are the fifth I have ever "met". The first was my father but are you a "ton" or a "ford". I'm a "ford"
I'm a ford also lol
Clifford
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby PanelDeland » Thu Sep 01, 2011 4:28 pm
VELCRO
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
Re: My version of back hatch supports
Postby chartle » Thu Sep 01, 2011 4:38 pm
BillZ wrote:Image
Since this popped again I see a problem with any kind of latches.
Since your hinges are above the level of your spars. Not sure if this was by design to give the supports a little bit more support but hinged in that way you are going to have issues.
chartle
Postby LDK » Tue Nov 01, 2011 6:28 am
This is how I did my hatch props.
LDK
Postby Moho » Tue Nov 01, 2011 9:08 am
If it were me, I'd go back to the broomstick and install a universal joint coupler on a dowel (broomstick) and then a short dowel inserted into a block mounted on the galley lid. There are a ton of places which have them with up to a 1" bore. You can get a double if the articulation isn't far enough on a single.
This would allow you the small amount of side to side moevment in order to install clips on the lid like Woodbutcher.
If you want to go with the make it yourself option....
Moho
Images: 69
Postby hoytedow » Wed Nov 02, 2011 7:48 am
Clever!
Happy trails,
Hoyt
hoytedow
Images: 19
