I have finally begun the build. I was working on a solar hot water project and that is almost done. now I can focus on the TD.
First up was to make a workbench big enough to handle the sheet goods, wall panels, etc. I'll add an MDF top, but for that I will need a trailer to get a full sheet home. So next was to start building the HF trailer. It was very handy to have the whole thing at a comfortable working height.
I am planning to put the axel 37.5 inches from the rear of the trailer frame. I'll be building a 4x10 Modernistic style so the curve extends out over the frame. Does this position sound about right? I will have a galley with small stove and cooler in the back.
The Bench so far. Assembled with pocket holes and no glue so I can dismantle it easily when the trailer is finished. This assumes that I am only building 1. (
Is there some fore shadowing here?)
Partially assembled trailer.
C channel being inserted to strengthen the joint.
I am assuming most people cut off the tabs where the casters are suppose to be mounted, correct?
Cheers all. Thanks for all the wonderful advice you did not know you gave as I have been studying the posts for a while now.
Onno
