mcspin50 wrote:Sharon,
Way to go!!!![]()
The My Away looks wonderful in its natural habitat!
Congratulations on a job incredibly well done!
Happy camping,
Thanks, Lil. Congratulations on your cute Scamp!
Way to go!!!![]()
Happy camping,
georgie wrote:I've been looking throur your build sharon, excellent job
I've been looking at the tear drop campers and came across the compact design, with the elevating roof.
due to my limited movement in my back i needed the extra height and that desighn seemed just the job.
Sharon as a person that has built one are there any tips that you could pass on to a fellow builder?
how long did your build take to complete?
sorry for all the questions but as they say, if you don't ask you'll never know
I look forward to your advise
thanks mark
S. Heisley wrote:Thanks, Mike, Larry, & Becky!
Yes, I had a good time but had sweaty palms coming home though...still learning things about towing, especially backing up!.![]()
...The Jefferson State TearJerkers are a great group of people.
S. Heisley wrote:georgie wrote:I've been looking throur your build sharon, excellent job
Hi Mark,
First, thank you for you kindness and your inquiry.![]()
I don't know what your exact physical condition causing limited movement is; but, please recognize that a lifting plywood roof can be heavy. By hinging one end, the weight is cut roughly in half, which really helps. I added what is called a pad eye (from West Marine) to the front of mine and purchased a push-pull pole (also from West Marine) to lift my roof. That helps; but, it's still like lifting a child weighing 35 pounds or more above your head.
A couple of strategicly placed gas lift struts could reduce that weight by a LOT. A pair of these, http://www.grainger.com/Grainger/BANSBA ... Pid=search in the right spot might well make a pop top raise on it's own, and you'd need a rope attached to pull it back down for travel. You might have to test with a spring scale to get the ones with the correct force, or it might go up, and need a block and tackle to pull it back down
S. Heisley wrote:Jeff, regarding using lifts or an actuator like Mike (Myoung) used, shown here: gallery/image_page.php?album_id=336&image_id=79727
These mechanical lifts would require using something other than plywood lifting/folding sides or a deliberate change in the lifting roof design to allow for the lift housing. I would imagine that snap-on canvas could be used or the lifting roof might be made wider than the opening so that the non-human lifting mechanism could be housed between the stationary lifting roof lip and the point where the lifting roof rests on the stationary roof top.
For now, I am reasonably happy with the folding wood sides and my lift method, and I believe Myoung is happy with his lack of lifting sides and his lift method; but, people wishing to build this style of trailer should be aware of these issues so that they can design whatever is best for them.
PcHistorian wrote:Wow! That looks incredible! The wood work is phenomenal! (Interior) The packed and unpacked exterior look first rate, too!
Have you named it? (The "MyAway"?) Have you christened it? ;-)
Looking at your interior, the idea strikes me as "We REALLY need to come up with a set of annual awards for these trailers. Set up categories like 'innovative design', new materials, best interior by an amateur, best by hand tools only, best alternative (non-tear) design, etc..." stuff like that. Maybe have them at the Tear-In's, instead of annually, or annually also. But looking at your build and the categories, I think you'd be at the top of several of them with that one.
