Which pocket hole jig?
Postby pohukai » Fri Sep 30, 2011 4:44 pm
Which pocket hole jig did you use and/or prefer for building your TD that has different wall/galley wall thickness (3/4" and 1/2" ply)? The R4 ($99), the R3 ($40), the Kreg Jig mini ($11) or a different mfg's jig?
The R4, looks like the top of the line, but it may be overkill or possibly cumbersome. I'm not sure if the R3 handles different wall thickness. :roll:
Thanks
Jim
pohukai
Images: 9
Re: Which pocket hole jig?
Postby KenC » Fri Sep 30, 2011 5:18 pm
pohukai wrote:Which pocket hole jig did you use and/or prefer for building your TD that has different wall/galley wall thickness (3/4" and 1/2" ply)? The R4 ($99), the R3 ($40), the Kreg Jig mini ($11) or a different mfg's jig?
Thanks
Jim
Welcome Jim,
I used the R3, my walls are 1 1/4, only used it on the framing which is 3/4. I see we are neighbors as well
KenC
Images: 41
Postby Moho » Fri Sep 30, 2011 6:00 pm
I got the R4, main reason is I didn't like the look of the flimsy sides on the R3. Any of them will handle the same thickness of wood, it more a matter of ease of placement of the jig. The bench mount option on the R4 is nice but for mobile use the R4MS would be the quickest setup.
Bottom line they all work it's just a matter of how quickly you want to be able to place the jig and drill.
Moho
Images: 69
Postby planovet » Fri Sep 30, 2011 6:19 pm
I used the Kreg Jig® Jr. :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby terryjones1 » Fri Sep 30, 2011 6:44 pm
I have #K4
I have tried using with 1/2 " thick wood and 3/4" thick wood.
In my experience. it works pretty good with 3/4" thick wood.
Also, in my experience, it doesn't work very well with 1/2" thick wood.
I would definently not recommend the jig for 1/2" thick wood.
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby neil and ramona » Fri Sep 30, 2011 6:44 pm
planovet wrote:I used the Kreg Jig® Jr. :thumbsup:
The guy who invented this should be a millionare,if he's not we should take up a collection.I don't know how that i made so many years without one,and now it scares me if i start running low on screws or my bit gets a little dull.
neil and ramona
Postby mikejames » Sat Oct 01, 2011 1:19 am
I really like the Harbor freight jig. It's built very well and has great reveiws. Also priced right.
Hope this helps,
Mike
mikejames
Postby Jpageau » Sat Oct 01, 2011 6:21 am
I just got the kreg jig jr.
Jpageau
Postby Larry C » Sat Oct 01, 2011 8:15 am
mikejames wrote:I really like the Harbor freight jig. It's built very well and has great reveiws. Also priced right.
Hope this helps,
Mike
The HF jig looks really good. Anyone else use it?
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
w
Postby john curtis » Sat Oct 01, 2011 9:34 am
Kreg Jig
john curtis
Images: 141
Postby Billy K » Sat Oct 01, 2011 7:35 pm
Kreg is the way to go...just study their site and decide which fits your needs.
Invaluable tool.
"...influence is no government." - George Washington
Billy K
Postby NathanL » Sat Oct 01, 2011 8:06 pm
I think the Harbor Freight jig is a better jig than the Kreg, I have both. However it is more expensive and doesn't come with great instructions.
The HF jig really is made for stationary use on a bench, if you need something you can move around like the little Kreg it won't work for that.
NathanL
Postby myoung » Sat Oct 01, 2011 11:52 pm
The Kreg Jr. worked for me in every situation. It is adjustable so I doubt you will have any problem with this terrific device.
Mike Young
myoung
Images: 250
Postby Larry C » Sun Oct 02, 2011 7:02 am
NathanL wrote:I think the Harbor Freight jig is a better jig than the Kreg, I have both. However it is more expensive and doesn't come with great instructions.
Thanks Nathan! That's what I was looking for, somebody that has actually used both brands. I know all the good things (some not so good) that have been said about the Kreg, but the HF tool sure looks more robust.
As far as the HF cost. It sometimes is on sale, and with a 20% off coupon, it's about the same price (or less) than the Kreg.
Most everything at HF has lousy instructions, but I found a u-tube video on using the HF jig. Your point about bench mount vs portable may lead me to the kreg tool anyway.
Has anyone had any luck using non pocket hole screws which are expensive?
Larry C
Larry C
Images: 78
Postby NathanL » Sun Oct 02, 2011 11:48 pm
Porter Cable makes a pocket hole jig as well. Seems overly complicated to me but it has a quick release clamp to hold the wood etc...Of course it's priced at over $200.
Home Depot has a no name brand mini pocket hole jig similar to the Kreg one that is all aluminum for $20-$30.
NathanL
