CaseyKraft 2 -- updated 11-5-2011
Postby caseydog » Wed May 26, 2010 7:13 pm
Billy K wrote:CD - just a thought ...someone mentioned the "curved- look"...
I get the straight and plain idea ...if you had enough scrap lying around ....how about a TD profile table and a concave curved support??
The table would allow you to wobble past and the upswept support would allow for safer knee slapping.....
other than those two cent thoughts; Cheers - Nice build.
Some Saturday evening, with enough liquid motivation, I could see myself making a TD shaped table. Or, at least somewhat TD shaped. ;)
CD
My build journal is HERE
caseydog
Images: 515
Postby steve smoot » Thu May 27, 2010 2:20 pm
Calling Caseydog...come in CD....
I'm bumping your build threar back up to the top...cause...I have a guestion about your wiring...
I am using the same Marinco 15 amp 125 volt entrance device that you have, and I am using a 15 amp six-way, so that all 120v items will actually just plug-n-play...
What was your reasoning behind not just pluging your AC into the breaker protected six-way? :thinking: The system can not handle more that 15 amps total anyway.
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby caseydog » Thu May 27, 2010 3:51 pm
Steve, your description does not quite match my system -- I think. :thinking:
What I did was permanently attach the three conductors of a three-way cord to the inside of the Marinco pass-thru. I have a powerstrip plugged into that, which is mounted in the galley. When I need AC, I plug that directly into the three-way, as shown in the picture below. I do the same with my heater, when it is needed. Other things get plugged into the power strip for convenience.
CD
caseydog
Images: 515
Postby steve smoot » Thu May 27, 2010 4:57 pm
Yes, I understand what you have done.
My thought was to eliminate the three-way and tie the breaker protected six-way directly into the Marinco inlet. It just seems this will do the same thing, I will just have six outlets total vs your eight... :thinking:
steve smoot
Images: 62
Postby caseydog » Thu May 27, 2010 5:46 pm
steve smoot wrote:Yes, I understand what you have done.
It was the gauge of the wire that made the difference. I wanted to plug my high-draw heater and AC unit into heavy-gauge cable. I have at least 12 gauge going from the campsite shore power to my heater or AC as I have it set up now.
CD
caseydog
Images: 515
Postby steve smoot » Thu May 27, 2010 5:59 pm
Okay...that makes sense...guess I will follow suit.... :thumbsup:
steve smoot
Images: 62
Any
Postby Jeeper92 » Wed Aug 24, 2011 10:04 am
Any updates?
Jeeper92
Postby campmaster-k » Fri Sep 16, 2011 2:27 pm
CaseyDog . Permission to use the big dogs color scheme? I really like your colors just wanted to ask permission.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby caseydog » Sun Sep 18, 2011 5:03 pm
campmasterk wrote:CaseyDog . Permission to use the big dogs color scheme? I really like your colors just wanted to ask permission.
Go for it. :thumbsup:
CD
caseydog
Images: 515
Re: Any
Postby caseydog » Sun Sep 18, 2011 5:06 pm
Jeeper92 wrote:Any updates?
Nothing new, except an umbrella thingy. I may have a picture.
If I do anything, it will be during the winter months, when it is bearable to work outside.
CD
caseydog
Images: 515
Postby caseydog » Wed Oct 05, 2011 10:13 am
I finally found a "round tuit" laying around, so I could make this much needed little improvement.
I have always used a hardware box for my kitchenware storage, but always had to pull it out and set it on top of something to open it. There isn't always counter space free.
So, I put the storage box on drawer slides so I can pull it out, open and close it, and push it back.
I'll try to find another "round tuit" and photograph the umbrella mount.
CD
caseydog
Images: 515
Postby aggie79 » Wed Oct 05, 2011 11:57 am
CD,
Besides being a handy modification using the drawer slides, I like the idea of using the tray itself as a utensil tray!
Take care,
Postby caseydog » Wed Oct 05, 2011 3:49 pm
aggie79 wrote:CD,
Take care,
I used that in my LittleGuy, too. It keeps dust and dirt out, which is nice in the great outdoors, and also when my TD is stored in the garage.
CD
caseydog
Images: 515
Postby 2bits » Wed Oct 05, 2011 10:10 pm
Ever thought about building a drawer there? I just see alot of opportunity to use the rest of the space in the drawer hole. What you've got definitely works tho.
Thomas
2bits
2bit Member
Postby caseydog » Thu Oct 06, 2011 11:40 am
2bits wrote:Ever thought about building a drawer there? I just see alot of opportunity to use the rest of the space in the drawer hole. What you've got definitely works tho.
I have kicked around the idea of built-in drawers, but haven't been motivated to buy the stuff and build them. I'm more about camping than building.
CD
caseydog
Images: 515
