If anyone has done the above exterior combo please post your thoughts and some pics to help me settle my mind!
Thanks!
Robbie
Robbie wrote:Thanks Tom. I've looked at Planovets build and his paint job is amazing! I looked into it but can't find any local distributors so shipping it would be costly and its a multi-part system where as the Rustoleum is a single part paint that costs about as much as regular house paint. I know you get what you pay for but if I was gonna spend a bunch on paint I'd just go back to aluminum.
Robbie wrote:I'm not worried about a less than perfect finish (ie: not glass smooth is ok). The Rustoleum Enamel is the same paint that Zach used on his URABUS convertible build and his has a slight texture like when you paint the walls in your house and it looks good. I was more concerned how the gloss white paint looked against the EPDM which is more of a matte finish. Probably won't even tell but I was just curious. If I do it this way I plan on sealing the walls with a coat or 2 of CPES, then 2 coats of primer, light sanding, and 2 or 3 coats of paint. And then Sikaflex sealant along the entire perimeter of the EPDM with a slight overhang (1/4") down the walls and trimmed with aluminum angle.
