mikeschn wrote:Aligator944 wrote:Mike,
How are you planning to finish the inside of the roof?
I plan on doing the inside with canvas and paint too. I don't think we are going to do anything with the kerfs on the inside. They will show through the canvas a little bit, but it shouldn't be too bad.
I think I will cut the canvas into 2 1/2 foot wide pieces and just cover one section and two spars at a time.
Just a thought, Mike...would it be more time-effective to tack a full-length canvas piece up to the ceiling with a batten at each spar that's narrow enough so that the majority of the spar is accessible for gluing (say, 1/4" wide batten on 3/4" wide spar?), and then once that's dried, remove the battens and coat that area?
Might also deal a little better with any shrinkage that way?
Enjoying the build...
David
