by TJinPgh » Fri Oct 28, 2011 1:59 pm
Hiya.
New here but watching this thread with great interest.
Since you seem to be at the point where you're going to start skinning the outside soon, I was curious about something for a possible coating.
Since the foam can be primed (right?), has anybody considered the possibility of using bedliner coating to cover it with?
The stuff is lightweight, extremely durable and can either be sprayed or rolled on, depending on the volume of it you need.
It's normally purchased in black but other colors can be ordered or it can be painted.
I tried spraying some of the rustoleum brand of it on a simple piece of styrofoam and it melted a good bit. The duplicolor brand I used to spray the plastics on a motorcycle was clogged so I didn't get to try that but I'd imagine it would do the same. If the piece can be primed first, though, that wouldn't be a problem, I'd think.
Just thought it might be worth considering?
-TJ
-TJ
