Foamie Boat- Update 6/19/12
Postby Papi » Tue Nov 15, 2011 9:48 pm
This boat might just end up in the Hall of Foam...er, fame! 8)
You just got my future project list to grow one more notch...
I dream of a day when a chicken can cross the road without having his motives questioned.
Papi
Images: 50
Postby GPW » Wed Nov 16, 2011 8:16 am
Glad you got that fixed ... probably a bad spot in the wood of the first piece ... Are you putting a full length Keel on the bottom ... ? That would really tie the whole hull together ... :thinking:
Are you planning an upper deck of some sort .. ??
Postby Rosey » Fri Nov 18, 2011 8:33 pm
I have some progress to report!
Here is a picture of the bottom being glued on.
I used a round over bit with a bearing to cut the out the shape of the bottom.
It left a pretty big ridge around the edge.
A small multi-rasp plane smoothed the edge down in no time!
Rosey
Images: 66
Postby StandUpGuy » Fri Nov 18, 2011 9:44 pm
Before you go through the trouble and expense of glassing this boat, do you think you can do a stability test on water?
StandUpGuy
Images: 52
Postby GPW » Sat Nov 19, 2011 8:13 am
Rosey , looking Good !!! I see where you’re going with this ... ;)
Postby Rosey » Sat Nov 19, 2011 8:48 am
StandUpGuy- I won't be able to take it to the water until after it's covered. I don't think it will survive the car top trip. I'm really not too worried about the stability on the water. The boat is about the length of a canoe and a little wider.
Rosey
Images: 66
Postby Wolffarmer » Sat Nov 19, 2011 9:23 am
She is going fishing.
Randy
Wolffarmer
Images: 309
Postby GPW » Sat Nov 19, 2011 9:46 am
Can’t be any more tippy than a Pirogue :o This one should be Much better with twice the freeboard ... ;)
Idea: Having built a few Tippy boats in my youth , I quickly learned the advantage of the “outriggerâ€
Postby atahoekid » Sat Nov 19, 2011 12:27 pm
Looking good Rosey... Your foam project has me thinking about my strip built kayak project that never has gotten off the ground, I've been re-reading all my research material and thinking about making that the next project after I finish the Road Foamie. HMMM, Maybe I can incorporate foam and canvas building methods into it... :thinking: :thinking:
Mel
atahoekid
Images: 158
Postby DJT » Sat Nov 19, 2011 11:02 pm
Something I found, might give someone ideas for building a boat shaped TD?
http://www.instructables.com/id/Foamboat-construction/
DJT
Postby eaglesdare » Sun Nov 20, 2011 7:35 am
that is looking really good. can't wait to see the pics when its in the water. :thumbsup:
Louella
May the foam be with you.
eaglesdare
Postby StandUpGuy » Sun Nov 20, 2011 9:11 am
Where will the seats be located in this boat?
StandUpGuy
Images: 52
Postby Rosey » Tue Nov 22, 2011 3:51 pm
the plan has one seat about 2 ft from the rear of the boat. the second seat is a ditty box that can be moved as needed for weight distribution.
Rosey
Images: 66
Postby GPW » Wed Nov 23, 2011 6:50 am
Ditty box , or more appropriately to this area .... Beer cooler .... the official Foamie ballast ... 8) :lol:
Postby StandUpGuy » Tue Nov 29, 2011 10:09 pm
Whats the dealio on the boat. We need updates! :lol:
StandUpGuy
Images: 52
Users browsing this forum: jgmahoney and 15 guests
