Tiny Cargo trailer conversion...???
Postby aggie79 » Thu Nov 17, 2011 10:01 am
GPW,
You can get heavy-duty drawer slides that are rated to 500 pounds and probably greater. The ones I've seen - the heavy duty ones - are available in stainless steel. I'm not sure what the bearings are though. They're metal, but I'm not sure if they are stainless.
The drawer type slides attach through the faces. I've seen TV drawer slides that have a 90 degree backet that would allow you to attach them to the top or bottom.
The part I can't get my head around is how to design the seals. I keep going with an inner flange design, almost like a drawer face, that would seal around the inside wall of the trailer. The problem is that I can't resolve how to have lower part of the flange and have it clear the supporting structure of the drawer.
Sure wish we could see some more details of this.
BTW - the idea that keeps coming to me is not a slide out to the side, but one that extends out over the tongue when camping.
Keep the ideas coming GPW.
Take care,
Postby GPW » Thu Nov 17, 2011 11:31 am
Tom , Big Drawer slides ... That’ll work !!! Cool idea , Thanks !!! 8) I think the seals would need some type of rubber flap outside and the usual weatherstripping in and out on the flanges of the “boxâ€
Postby GPW » Sun Nov 20, 2011 7:40 am
Anybody got an idea how to make a slide out ... just a big Box eh ??? Would plywood work ... ? This was all I could think of ... seems simple enough ??? :thinking:
http://tnttt.com/album_ ... c_id=85212
Postby StandUpGuy » Sun Nov 20, 2011 9:17 am
GPW wrote:Anybody got an idea how to make a slide out ... just a big Box eh ??? Would plywood work ... ? This was all I could think of ... seems simple enough ??? :thinking:
I would think you would require a platform on the inside at the same height as the underside of the slide out box bottom. The platform would need to be as deep as the un-extended shelf slider. The platform could be "rabitted out" to make the drawer slider flush with the platform. Since you want the slide out as a bed extender this would work well.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Nov 20, 2011 9:20 am
You could even have a set of drawer sliders in the top of the slide out box too. You could make an overhead cabinet that would extend down from the ceiling to be flush with this set of sliders.
StandUpGuy
Images: 52
Postby GPW » Sun Nov 20, 2011 2:50 pm
SUG, something like this ? Image
Postby StandUpGuy » Sun Nov 20, 2011 8:20 pm
exactly like thatGPW! Only you do end up with the box extender being atleast the thickness of the plywood higher than the inner bed. Also I could see building cabinets over the bed too and placing a heavy duty shelf slider into the underside of those cabinets. Lets face it you will not need gobs of headroom over the bed and you will not have much else for storage elswhere so it might be something to consider. Looks like you have it figured out.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Nov 20, 2011 8:29 pm
Remember Roly Nelson's little 3x3 trailer? He had a pivoting extension instead of a slider. That was very simple. You just need feet room like maybe 2.5'.
Have a look at the thread:
http://tnttt.com/viewto ... box#860156
Sorry for the bad paint quick sketch but maybe you can get the idea of it:
By justoneman at 2011-11-20
StandUpGuy
Images: 52
Postby GPW » Mon Nov 21, 2011 8:51 am
SUG, it’s such a small CT , I was going for all the space I can ..
Thinking now about making it in the biggest part of the trailer, up front ... :thinking:
Postby GPW » Mon Nov 21, 2011 9:32 am
Went outside and drew a couple lines on the trailer ... I can fit almost a 48â€
Postby eaglesdare » Mon Nov 21, 2011 9:44 am
oh how cool glen! i had no idea you were building something like this. will keep my eye on it now.
Louella
May the foam be with you.
eaglesdare
Postby StandUpGuy » Mon Nov 21, 2011 11:07 am
[quote="GPW"]Went outside and drew a couple lines on the trailer ... I can fit almost a 48â€
StandUpGuy
Images: 52
Postby GPW » Mon Nov 21, 2011 2:50 pm
Eagle , I’ve had this one ... Might as well make it work ... :roll:
SUG, Good points !!! ... More planning /thinking needed on this ... :thinking:
