hoytedow wrote:That's a pretty nice link, actually.
There are others.
http://tweetys.com/rv-lighting.aspx?gcl ... 4AodIVF54g
SubaruDave wrote:Found some nice 12V lighting fixtures which are decently priced.
http://superlumination.com/fixtures.htm
What other stores/websites does everyone else use for their 12v lighting?
SubaruDave wrote:Did some more thinking today and searching and searching for something to suit my needs, or to see if its even been done... I've seen RVs with slide out sections and I would like to do the same with a cargo trailer. I could try to make it from light materials, like foam or something similar. I can make it weatherproof by covering the entire thing in FRP or another lightweight material.
Since I was thinking about going with a 6x12 or even 6x10, what if I built the slide out section to come out 3 or 4 feet of the rear of the trailer when the doors are open, that will keep me from having to make it weatherproof when closed (because the doors will cover it), also it will allow me to have more windows if I would like. and it would also keep the weight over or close to the trailer axle when in transit, and not add anything to my tongue weight.
The only issue is where can I get the hardware to do so?
