10' Standie Foamie ... on hold
Postby aggie79 » Wed Dec 21, 2011 11:35 am
What about take GPW's idea, but substitute the hot wire with a piece of sharpened spring steel like a cabinet scraper? The steel should be sufficient enough to cut thorough the foam.
Postby Wolffarmer » Wed Dec 21, 2011 11:41 am
A few days ago I used a very sharp knife to try and cut the foam. It works to a very small depth. Then it just starts pushing foam and breaking. Need a sawing type action, or the hot wire. Or just break it.
Randy
Wolffarmer
Images: 309
Postby GPW » Wed Dec 21, 2011 12:24 pm
Actually the careful use of the belt sander to remove the heavy stuff and an oscillating sander to smooth it out is really the easiest way to go ... messy , but easy ... for less messy you could use an electric carving knife to remove the bulk of it in large chunks ... just like carving a Turkey .... something we should be well practiced at by the end of next week ... :roll:
Some “guideâ€
Postby Tiredoldwhiteman » Wed Dec 21, 2011 1:37 pm
GPW wrote:Actually the careful use of the belt sander to remove the heavy stuff and an oscillating sander to smooth it out is really the easiest way to go ... [snip]
While I'm a big fan of hot wire cutters & knives, for this application GPW's got the right idea. IMO, simplicity always wins out...
Tiredoldwhiteman
Images: 5
Postby swampjeep » Wed Dec 21, 2011 1:52 pm
I like teh electric carving knife idea, I need to get me one...
swampjeep
Postby bonnie » Wed Dec 21, 2011 2:43 pm
figures. I gave mine electric knife to one of the kids. I hadn't used it in years. :)
I saw a pvc saw that was a single strand of cutting material with padded loop handles at each end. Wonder if it could be rigged up to work and cut angles? Maybe with some sort of jig?
Remember, the turtle won. :)
bonnie
Images: 107
Postby crumbruiser » Thu Dec 22, 2011 5:27 pm
Thrift stores usually have electric knives for cheap.
In talking about the hot wire cutters, could a hacksaw blade be heated and bent to the chosen radious and then be incorporated into the cutter instead of a wire?
Frank
I am not weird, I am a Limited Edition.
Facebook http://www.facebook.com/profile.php?id=100000303236631
crumbruiser
Images: 255
Postby GPW » Thu Dec 22, 2011 6:35 pm
Frank , I don’t think that would work very well... you’d need a lot of current to heat it ... :o
No use taking something real easy (but messy) and complicating it ... ;)
Postby gullywompr » Tue Dec 27, 2011 11:59 pm
This movie shows how to radius foam with a wooden radius block. Description of the block is about three and a half minutes in, demonstration of usage about five minutes in. Never tried it myself, but to me it looks to be easy and quick.
http://www.youtube.com/watch?v=M9-CCvl3KUs
Cheers,
Curtis Olson
gullywompr
Images: 7
Postby atahoekid » Wed Dec 28, 2011 1:18 am
Thanks for posting that video. That is what I thought of trying but was unsure of the results. Seems like it will work just fine. :thumbsup: :thumbsup:
Mel
atahoekid
Images: 158
Postby mikeschn » Wed Dec 28, 2011 2:18 am
I don't think our pink EPS is quite that soft, but I do think the radiused block will work on it.
Postby GPW » Wed Dec 28, 2011 7:00 am
The foam used in the video is Urethane foam , which sands very easily , and doesn’t tend to tear out as easily as the extruded styrofoam .. Big difference in working properties ... The radius block will tend to tear out the Styrofoam if not used very carefully ... been there ...
A good random orbital sander might be better for rounding Styrofoam ... belt sander for bulk stock removal , then finish with the RO sander ... Easy !!!
Postby mikeschn » Wed Dec 28, 2011 7:54 am
I will go out and experiment for a little bit today. Not sure how long I'm going to stay out there today, as it's 20° F. here.
On the other hand, if I could find a way to heat the garage, I could get small wheels on the foamie, and get the foamie in the garage, I might stay out there a little longer.
We tried a 1500 Watt room heater yesterday, didn't even make a dent in the temperature.
Any ideas?
Postby mikeschn » Wed Dec 28, 2011 8:02 am
I have one of these... I think I'll try it today.
Postby GPW » Wed Dec 28, 2011 8:56 am
Time to Foamie the Garage ... :thumbsup:
Are you to the point where you can work inside the Trailer , gotta’ be easier to warm than outside ... 20 F , BRRRR!!!! :shock:
