by eamarquardt » Fri Dec 23, 2011 5:47 pm
If you have a battery don't see a need for a converter. A small battery charger will put in over 100 amp/hours over 24 hours and replace all but the biggest draw over time. I can't see a need for a 40 amp converter. Boaters live "off the grid" and use only batteries so why not a teardrop.
One thing I'm considering is using a solar controller with some solar panels (have these on hand) and instead of a battery charger just a simple surplus power supply or other new power supply and run it as the input to the solar controller when the solar panel is not on line. Simple and fewer components but if the solar controller fails you're SOL. Just kicking around the idea.
However, a converter can be had for about the same as a good charger so why not. A converter also has a "load center" with breakers and fuses.
So, consider all the options before jumping on the converter bandwagon.
Cheers,
Gus
