glenpinpat wrote:the type of stove you have is not for a trailer as per vozelgang's website. They state may not be installed in mobile homes, manufactured homes, trailers or tents(no exceptions). You would have to move to a marine type stove as already mentioned. The problem there is that you would have to cut a big hole in your trailer for the stove pipe and this will cause leak problems while driving down the highway. You are much better of with a vented catalytic propane heater that can be pulled out of an rv for very few dollars or bought for about 250.00. Patrick
ISeenBigFoot wrote: im also going to head west where there is plenty of BLM and other forests to camp in. ive had it with flat HOT fla.
Wolfscout wrote: * Indoor-safe portable propane heater for rooms up to 100 square feet
* Low-oxygen sensor and accidental tip-over switch with auto shut-off for safety
* Measures 12 by 10-1/2 by 10-1/2 inches; 1-year limited warranty
Per the manufacturer of the Little Buddy model mentioned:eamarquardt wrote:Wolfscout wrote: * Indoor-safe portable propane heater for rooms up to 100 square feet
Yer betting your life with an unvented heater in a pretty much sealed small space.
Gus
Per the manufacturer of the Little Buddy model mentioned:warnmar10 wrote:eamarquardt wrote:Wolfscout wrote: * Indoor-safe portable propane heater for rooms up to 100 square feet
Gus
