We tried that last summer.. Chell put the impression of an iron into the foam. No more ironing on the foam.
mikeschn wrote:Cliffmeister2000 wrote:Mike, I haven't seen where you posted what cracked?![]()
Ah, you're right.
Here's the crack. I've since filled the crack in with gorilla glue, and it's just waiting to be sanded back down.
bonnie wrote:The ribbon I would recommend is grosgrain ribbon. It's finished on both sides and edges and is fairly sturdy. You would want to test it with the glue before you commit to buying enough for the seams. It comes in differing widths and colors.
Bonnie
