10' Standie Foamie ... on hold
Postby mikeschn » Sun Jan 01, 2012 6:11 pm
We tried that last summer.. Chell put the impression of an iron into the foam. No more ironing on the foam.
Postby RAYVILLIAN » Sun Jan 01, 2012 8:45 pm
Mike
I found this by accident. When I was sealing in the hole I cut for the AC I got a couple of runs down the outside of our trailer next to a seam. I tried sanding them with my sander and 100 grit. Didn't get rid of the runs but smoothed out the material fuzz and smoothed out the seam a little. You might try that on your seams in a corner and see how it works.
Gary
PS I had 4 coats of paint on the trailer though 2 of latex primer and 2 of oil base finish.
111961Image
RAYVILLIAN
Images: 109
Postby GPW » Mon Jan 02, 2012 7:00 am
Mike , guessing that was a case of "striking while the iron was Too Hotâ€
Postby millstone » Mon Jan 02, 2012 9:40 am
How about cove moulding? I think either wood or plastic would make the curve.
millstone
Postby Cliffmeister2000 » Mon Jan 02, 2012 9:53 am
mikeschn wrote:
Cliffmeister2000 wrote:Mike, I haven't seen where you posted what cracked? :thinking:
Ah, you're right.
Here's the crack. I've since filled the crack in with gorilla glue, and it's just waiting to be sanded back down.
If that's a major stress point, I wonder if it would be a good idea to make a cut (kerf) clear across the width of the trailer, and fill the kerf with spray foam that you can sand before covering the outside?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby mikeschn » Mon Jan 02, 2012 5:08 pm
Too late Cliff, It's all glued up. I think it'll be okay now!
Postby mikeschn » Mon Jan 02, 2012 5:10 pm
GPW,
Those fabric ribbon thingies sound interesting. IT would cover the cut tabs for sure.
Postby bonnie » Mon Jan 02, 2012 5:38 pm
The ribbon I would recommend is grosgrain ribbon. It's finished on both sides and edges and is fairly sturdy. You would want to test it with the glue before you commit to buying enough for the seams. It comes in differing widths and colors.
Bonnie
Remember, the turtle won. :)
bonnie
Images: 107
Postby mikeschn » Mon Jan 02, 2012 7:43 pm
bonnie wrote:The ribbon I would recommend is grosgrain ribbon. It's finished on both sides and edges and is fairly sturdy. You would want to test it with the glue before you commit to buying enough for the seams. It comes in differing widths and colors.
Bonnie
Hey, that looks interesting.
Postby GPW » Mon Jan 02, 2012 8:30 pm
:thumbsup: That’s the stuff , and more ... Maybe just Hot Glue it on in the best Crafty manner... Now if they just had a 3â€
Postby bonnie » Mon Jan 02, 2012 8:43 pm
Hot glue will certainly work. It might need a pin or two to hold it until the glue sets up. It doesn't ravel as much as many of the more decorative ribbons would.
A quick google brought up this site. The ribbons come up to 2.25" wide. Don't know anything about the company, but should give you an idea of what's available. Avoid anything with wire edges.
http://www.papermart.com/Product%20Pages/Product.aspx?GroupID=10072&SubGroupID=10073#10073
bonnie
Images: 107
Postby GPW » Tue Jan 03, 2012 6:44 am
Thanks Bonnie , lots of Goodies there...
This would look Nice on the outside ... strong , Cheap ... textured ... 8) http://www.papermart.com/Product%20Page ... 6053#36053
Postby eaglesdare » Tue Jan 03, 2012 6:53 am
do not use crafters hot glue. i tried a couple of things using that last year and it just doesn't hold up. i did however run a thin line of gg right down the middle of what i needed to glue, and that worked great.
for something like this, IF you try gg, use a very thin line, and hold down flat.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Tue Jan 03, 2012 7:38 am
Eagle , I think getting the right hot glue is the real trick ... I use The High temp HG ... “the more expensive “Ultimateâ€
Postby Gerdo » Wed Jan 04, 2012 9:56 pm
Nice looking build. I have had a busy year and haven't been here much lately. I come back to find this. What do you think the final weight will be?
Gerdo
Images: 156
