6x12 Camper-Toy Hauler
Postby FatBoy BBQ » Mon Jan 02, 2012 11:39 pm
Hey Guys,
I am a 23 yr old camping/hunting/fishing etc. guy from East Central Illinois. I have had a large 5th wheel Jayco, a pop-up, and have recently chosen to start on a CT conversion.
I've been lurking and researching for some time and finally found a CT of my very own to get started on a conversion. This will be a simple camper/toy hauler with luxuries kept to a minimum. I'll be hauling a couple 4 wheelers and bunking with my g/f and dog.
The starting point. 1999 6x12 Avenger:
[img][img]http://i1032.photobucket.com/albums/a401/tshoudel/100_1499.jpg[/img]
Got some free foam insulation that was being thrown away at a local job site. I believe this is used to insulate gymnasium type roofs before applying the stucco material:
[/img]Image
Today I removed all of the Luan, re-attached a fender (blew off during a blow-out w/the previous owner) and just started insulating before the end of the day:
[img][img]http://i1032.photobucket.com/albums/a401/tshoudel/100_1500.jpg[/img]
Some damage from the previous owner. I believe she got into her mailbox when leaving the driveway. This is passenger side, right at the rear, about chest high.
I believe I will excise the damaged area, put in a plate of diamond tread or something similar, and install an RV type "porch light" within the diamond tread plate. This should utilize the existing hole, leaving a finished look. (pics to follow)
[/img]Image
Today was one of the coldest we've had in this area this winter. (high of 25 w/flurries) And was of course the first day I had time to start work. Much of the work was outside repairing the fender, but i stayed plenty warm.
WAAAY too much heater for a 6x12 box:
[img][img]http://i1032.photobucket.com/albums/a401/tshoudel/100_1505.jpg[/img][/img]
Build Journal- http://www.tnttt.com/viewtopic.php?t=48158
"A ship in the harbor is safe, but that's not what ships are built for."
FatBoy BBQ
Postby Blotto Bros » Tue Jan 03, 2012 2:00 pm
Great start and SCORE on that insulation...saved a BUNCH of money!!
Even those souls that are found must occasionally become lost to appreciate what they have.
Blotto Bros
Images: 51
Postby BC Dave » Wed Jan 04, 2012 12:17 am
welcome! I wish I had a 6x12 when I was 23! im double that; but good on you for finding the CT; there's tones of creative ideas to sift through here; take your time; prioritize and put all your ideas on paper; then hopefully you'll have less changes as you build ...
Free foam too; is that like the hard pink or blue foam?
be contious (as you probably know) of ventalation with propane cumbustion in enclosed spaces;like your CT; it uses oxygen and produces moisture and Co2 all of which could kill you; unfortunatly theres too many sad stories each year; did you feel headchy or drowsy?.
Cheers BCD
BC Dave
Postby FatBoy BBQ » Wed Jan 04, 2012 7:40 am
BC Dave wrote:welcome! I wish I had a 6x12 when I was 23! im double that; but good on you for finding the CT; there's tones of creative ideas to sift through here; take your time; prioritize and put all your ideas on paper; then hopefully you'll have less changes as you build ...
Cheers BCD
Thanks, I enjoy a couple small toys (for my age) because most of my things are old and wore out. (makes for plenty of DIY time) :-)
The foam is sort of white with dark thin cardboard on each side. think it was used for large gymnasium type roofing. with a cardboard layer so stucco material would stick better?
In any case the foam works: I looked outside while my heater was running and the only area that still had frost was where I had insulated the night before. (hence that area was holding the heat in)
I have read here about the dangers associated with such a tight space. While working I did not have any issues, but I had two heavy duty chords running through the back so the doors had a gap. I will be installing windows/vent as soon as I can.
FatBoy BBQ
