Satellite Dish Setup
Postby bdosborn » Mon Jan 09, 2012 11:10 pm
Well I couldn't help myself and I put a Dish Network receiver in the Boxcar. Despite the fact that we had one in the Teardop that I hardly ever used. I used an old dish that came with the house with a PVC ground mount that I made. I'm getting pretty good at setting up the dish, it only take me about 15 minutes.
The 311 receiver only draws 12 watts so the PV panel easily keeps up with it. I mounted the receiver underneath the front cupboards. Its AC only so I use an inverter to power it :
The extra receiver costs me $6 per month and I plug into the dish mounted on the house when we're home. Jean thinks I'm weird but I like to watch TV in the trailer ( in the garage). :wacky
Images: 806
Postby KenC » Mon Jan 09, 2012 11:39 pm
:applause: very nice :applause:
KenC
Images: 41
Postby eamarquardt » Tue Jan 10, 2012 12:02 am
I just looked at my Directv receiver and it draws 24 watts at 120 volts so I expect it would take about three amps to run an inverter and the receiver.
Given that you can only watch so much TV before it numbs your mind I agree the power requirements should be easy to manage.
One can use a computer with an adapter but I suspect a dedicated dvd player with inputs might use less power. How much does your player draw?
Cheers,
Gus
eamarquardt
Images: 150
Postby bdosborn » Tue Jan 10, 2012 12:21 am
eamarquardt wrote:One can use a computer with an adapter but I suspect a dedicated dvd player with inputs might use less power. How much does your player draw?
Our DVD player is kind of an energy hog, just the screen draws around 3 amps and using the DVD adds another amp.The portable we had before the ceiling mount only a used little less than an amp. The portable was optimized to run off a small battery while the ceiling mount definitely is not. Still, we only watch TV for an hour or so an evening and that's around 5 amp-hrs. Very manageable with 2 golf cart batteries and a solar setup. I'll replace the DVD with a laptop if it ever dies as it draws and costs about the same but does a lot more.
Images: 806
Postby CarlLaFong » Tue Jan 10, 2012 2:02 am
"Let's do a happy little painting today that will just make you feel good. I've covered the entire canvas with a thin even coat of the Liquid White, so let's get started. Lets go into just a touch of Phthalo Blue................"
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby Shadow Catcher » Tue Jan 10, 2012 6:10 am
I set ours up (Dish network) to use a three LNB antenna on four suction cups that can be stuck to the top or sides of Compass Rose or set up on the ground, the same mount can be used with the Jack TV antenna for over the air TV. We have yet to use it mind you but my thinking was bad weather or to be able to check weather in remote locations.
Postby GPW » Tue Jan 10, 2012 6:47 am
You guys really watch TV when camping ? .... Whatever happened to getting back to nature ...??? :roll:
Postby bobhenry » Tue Jan 10, 2012 7:25 am
GPW wrote:You guys really watch TV when camping ? .... Whatever happened to getting back to nature ...??? :roll:
They were talking about "satellite dish setup"
We all know how I set mine up ......
:lol: :lol: :lol:
Postby bdosborn » Tue Jan 10, 2012 8:41 am
I haven't been camping since I hung up my backpack. Sleeping in a trailer is "resort living" to me. :beer:
Images: 806
Postby bdosborn » Tue Jan 10, 2012 8:47 am
Shadow Catcher wrote:I set ours up (Dish network) to use a three LNB antenna on four suction cups that can be stuck to the top or sides of Compass Rose or set up on the ground, the same mount can be used with the Jack TV antenna for over the air TV.
Have you got a picture of that mount? I need to upgrade the dish to a dual LNB. I've got the dish but I can't catch two birds with the PVC mount as there's no way to easily level the dish. I was thinking of going with a tripod setup like this one:
Images: 806
Postby Shadow Catcher » Tue Jan 10, 2012 2:48 pm
Bob I went out and shot a couple of picturess for you.
With the Jack over the air
I think I have $30 in a used dish and the suction cup. I painted the dish blue with the face mat white It will get a CR sticker eventually.
Postby bdosborn » Tue Jan 10, 2012 9:45 pm
Hmm, nice setup. I'm gonna have to think about stealing that idea.
:twisted:
Images: 806
Postby Shadow Catcher » Tue Jan 10, 2012 10:19 pm
I have often said plagiarism is the sincerest form of flattery, and it was not entirely original :D
Postby Kevin & Sandy » Wed Jan 11, 2012 8:45 am
CarlLaFong wrote:"Let's do a happy little painting today that will just make you feel good. I've covered the entire canvas with a thin even coat of the Liquid White, so let's get started. Lets go into just a touch of Phthalo Blue................"
Up in this tree let's make a place here where a happy little squirrel could live. We'll make room for lots of his happy little squirrel friends....
:lol:
Kevin & Sandy
Images: 46
