Planning alum covering for 1/4 Nelson, Stacker (help!)
Postby Roly Nelson » Thu Jan 12, 2012 12:55 am
My bright blue and yellow 6ft long stacker, doesn't look right behind my new bright red Chevy Cruze. Therefore I am planning on skinning it with aluminum. As a woodworker, this is a first for me, and I need some info about correct thickness, available supplier in So Calif and bendable moulding. I'm sure it has been mentioned many times somewhere, but just thought I would ask. (Ugh, I hate working with fiberglass,) and now aluminum? It can't be as bad as the itchy stuff. Thanks for any help available. Oh yes, how much weight will be added to my 245 lb toy?
8) :? :cry: :thumbsup: Roly ~~
Roly Nelson
L'il Ol' Woody Builder
Postby eamarquardt » Thu Jan 12, 2012 1:43 am
.040" 5052 is a good thickness and alloy for what you want to do.
These guys are great:
Copper and Brass Sales Division
Los Angeles
13338 Orden Drive
Santa Fe Springs, CA 90670
Telephone: 562-623-4444
Sales: 800-926-2600
Sales Fax: 800-926-8310
It comes in 5X12 foot sheets. Each sheet weighs about 25# as I recall. There is a huge price break at 100# so buying 5 sheets is actually cheaper than buying 4. I'd be interested in 1 sheet if we can find buyers for enough to hit 100#.
Cheers,
Gus
eamarquardt
Images: 150
Postby halfdome, Danny » Thu Jan 12, 2012 10:40 am
Roly, if you want some premo anodized or mill finish aluminum check out,
Denco Supply
10280 Indiana Ct.
Rancho Cucamonga, CA
909.266.1804
The prices aren't cheap but the quality is top notch.
They have quite an assortment.
The underlined is what I have on my current build.
Aluminum Sheeting
032 4x8 032 4x8 White White Aluminum Sheet
032 4x10 032 4x10 White White Aluminum Sheet
040 2x2 040 24x24 White Masked 1 Side Aluminum Sheet
040 2x4 040 2x4 White on White Aluminum Sheet
040 4x4 040 4x4 White on White Aluminum Sheet
040 4x6 040 4x6 White on White Aluminum Sheet
040 36x72 White White Aluminum Sheet
040 4X8 040 4x8 White White Aluminum Sheet
040 4x8 BA 040 4x8 Black Anodized Aluminum Sheet
040 4x8 A I/I Ivory/Ivory Aluminum Sheet
040 4x8 A H/B 040 4x8 Heron Blue/White Aluminum Sheet
040 4x8 CB A 040 4x8 Chevron Blue Aluminum Sheet
040 4x8 BBG A 040 Bright Brushed Gold Anodized Aluminum Sheet
040 4X8 BBC A 040 Bright Brushed Clear Anodized Aluminum Sheet
040 4x8 BRC 4x8 Brushed Clear Aluminum Sheet
040 4X10 BG 4x10 Bright Gold Aluminum Sheet
040 4x8 BGA a 040 Bright Gold Anodized Polished Aluminum Sheet
040 4x8 BCA A 040 Bright Clear Anodize Aluminum Laminate Silver
040 4x8 A H/R 040 4x8 Hunter Red R/W Aluminum Sheet .040
040 4X10 040 4x10 White on White Aluminum Sheet
040 4X10 B/W 040 4x10 Black 1 side White 1 side Aluminum Sheet
040 4x10 BR A 040 4'x10' Bright Red Aluminum Sheet
040 4X10 BBGA Brushed Brite Gold Anodized Aluminum Sheet
040 4x10 BC Bright Clear Aluminum Sheet
040 4x10 BRC 040 Brushed Clear Aluminum Sheet
040 4X12 White on White Aluminum Sheet
050 4x8 White on White PVC 1 Aluminum Sheet
050 4x10 White on White Film Masked 1 side Aluminum Sheet
050 4x10 MF Mill Finish Aluminum Sheet
063 2X4 White on White Aluminum Sheet
063 4x8 White on White Aluminum Sheet
063 4x10 White on White Aluminum Sheet
080 2X4 White on White Aluminum Sheet
080 4X4 White on White Aluminum Sheet
080 4X8 White on White Aluminum Sheet
080 4x8 MF Mill Finish Aluminum Sheet
080 4x10 White on White Aluminum Sheet
090 4x10 MF Mill Finish Aluminum Sheet
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby robfisher » Thu Jan 12, 2012 11:12 am
Grant Whipp usually has molding in stock.
Rob
robfisher
Postby grant whipp » Thu Jan 12, 2012 12:43 pm
Hey, Roly!
What do you have in mind, finish-wise ... mill-finish alum., brushed, polished, or something you can paint red to match the Cruze?
If just mill, brushed, or polished, you can get away with .032" thickness (saving a few pounds), but if you are planning on painting, I'd recommend .040" in white (looks like you've already been given some excellent sources). With all the moldings needed to trim everything out, you'll probably add less than 50# to the trailer.
I've probably go all the moldings you'll need, but we'll need to talk before I can make any recommendations. If you want, give me a call ... I'll be out of town Friday & Saturday, though ... happy to help any way I can, my Friend ... :D ...!
grant whipp
Teardrop Manufacturer
Images: 117
Supplier
Postby nrody » Fri Jan 13, 2012 5:28 pm
Unicorn Metals 400 E. Lambert Rd, La Habra.
They have tons of new and recycled stock. When I go there it is like a treasure hunt. I get really creative ideas for some of the recycled stuff. They have small stainless sinks that would be ideal for a galley build. They have connex boxes full of plumbing and electrical and so much more!!! www.unicornmetals.com
nrody
Nancy
nrody
