So as I mentioned earlier, I am a deliberate cabinet maker, not having had much occasion to practice. But I do have some pics to offer as proof that sawdust continues to be made.
Let's see, I think that's a good first approximation of where I want the cabin cabinets to be....
And here's the solution, I think....
Cutting some ledger strips on a sunny winter northern California afternoon. "All the leaves are brown, and the sky is grey...." Only it was actually a beautiful day.
Transferring the curvy bit to to a router template.
Said template.
Next, rout the rough cut cabinet piece to the ceiling template.
Using the first profile as a template for the second-- riding the last 1/64 inch or so of that 1/8 in. template with the straight cutter bearing was nerve wracking, so I used the 1/2 in. copy as a template for the second vertical shelf component. MUCH easier!
Groooovin', on a sunny afternoon....
More sawdust being made.
Uh, ruh-roh. This is what we call "sneaking up on a fit." The upright dividers are still a bit snug, but a little 80 grit lovin' will smooth things right out. They'll slide into place like a poodle going under the wheels, smooth as silk with an occasional thump, after a little relief sanding in the morning. After that, work intervenes-- spring semester begins-- so progress on the trailer will likely slow. Unless this glorious weather continues. It's a joy to work late in the shop on cool winter nights, when it's dry and no colder than here on the north coast.
This is just the first dry fit, without face frames, which are not made yet.
Stay tuned. More sawdust is coming. I won't be able to sleep until those shelves fit correctly.
Mike C.
If it isn't broke, perhaps a more expensive tool is required to break it....
