12 Votl Wire source
12 Votl Wire source
Postby ukuleleblues » Sat Jan 21, 2012 8:47 am
I am goging to wire my trailer for 12 volts using a mixture of 12 v bulbs and LEDs. Any suggestions on what Gage wire, What wire types do you all use, Multi conductor wrapped, In-wall speaker wire, etc. Also where is a good place to get wire, salvage yard, online, etc. Thanks!
ukuleleblues
Postby Dale M. » Sat Jan 21, 2012 11:24 am
I like the following suppliers (links) for a lot of my wiring supplies...
http://www.delcity.net
http://www.waytekwire.com
Of course these are not the only ones...
For wire, ONLY NEW ... Some switches, lamp fixtures and speakers may be repurposed from whatever source they become available from (just avoid junk) ...
Dale
Dale M.
Images: 18
Postby Forrest747 » Sat Jan 21, 2012 12:12 pm
Home depot or lowes or most hardware stores. You can go as small as 20 gauge but 18 to 16 will do just fine. Stranded is what I used in mine but solid will work just fine.
Forrest747
Cowbell Donating Member
Images: 447
Postby kirkman » Sat Jan 21, 2012 2:34 pm
You don't want solid wire. I remember reading some where that it does not do well in a trailer because of all the movement it can break. I wish I could remember where it was I read it.
kirkman
Images: 55
Postby Forrest747 » Sat Jan 21, 2012 4:16 pm
If you are really interested, I suggest looking up AC43.13-1A Chapter 11, and AC43.13-2A. This covers all the aviation standards of wiring, splices allowed, cannon plugs, acceptable repairs, you name it. You can get it here. We use this for Boeing wiring of aircraft. Good enough for a 747 good enough for a trailer. A lot of trailer supply shops have wire. We use a lot 20 and 24 gauge in the 747. If you can go stranded. I used 14 gauge but only because it was free.
Also there is http://www.rowand.net/Shop/Tech/WireCapacityChart.htm which has a nice chart with different gauges and teh amps it can take.
Forrest747
Images: 447
Re: 12 Votl Wire source
Postby KenC » Sun Jan 22, 2012 11:16 pm
ukuleleblues wrote:I am goging to wire my trailer for 12 volts using a mixture of 12 v bulbs and LEDs. Any suggestions on what Gage wire, What wire types do you all use, Multi conductor wrapped, In-wall speaker wire, etc. Also where is a good place to get wire, salvage yard, online, etc. Thanks!
Here is link where I bought my 12 vlt DC gauge stranded marine grade wire. Free shipping as well. They have 10, 12, 16, 18 gauge
http://shop.genuinedealz.com/Marine%20G ... able%20RB/
KenC
Images: 41
Postby madjack » Mon Jan 23, 2012 1:25 am
...6R7 years ago, I bought a 250' spool of 4conductor trailer wire and have been using it for all(or most) of our wiring needs ever since...
http://order.waytekwire.com/productdeta ... 0PARALLEL/
madjack 8)
Postby PaulC » Mon Jan 23, 2012 1:39 am
madjack wrote:...6R7 years ago, I bought a 250' spool of 4conductor trailer wire and have been using it for all(or most) of our wiring needs ever since...
madjack 8)
We normally refer to that as "planning ahead" MJ :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby madjack » Mon Jan 23, 2012 3:03 am
madjack 8)
Cheers
Paul :thumbsup:
...hey, it has worked well for 3 campers and bunch of assorted projects....... 8)
Postby Aaron Coffee » Mon Jan 23, 2012 6:24 pm
I also use flat 4 trailer light wiring. I split it into two sets of two wires, I use the "groundier" color in each set for the ground, and the other no "groundy color" for power. I'm thinking I use Green, and brown for the ground. This creates a non standard color scheme, guess I should write the wring diagram near the fuse box.
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
