Homer Simpson moment - Doh, ebay. Thanks also GPW and pete42. I'm going out to find the soldering gun right now and give it a go. Will post results here.swampjeep wrote:ebay has a few transformers with controllers, might be able to get something there cheap,
if you can't wait, here's a brand new one for $28 + shipping
http://www.hobbylinc.com/htm/mrc/mrcaa300.htm
$22 +
http://www.activepowersports.com/model- ... ansformer/
$20
http://www.wholesaletrains.com/Detail.asp?ID=200418130
I also seen a bunch at our local flee market, but didn't look at prices, as I wasn't even thinking about this,
The 6" wire gave me enough length to form the shape I wanted. I figure a slightly smaller gauge wire will get me the performance nedded. I've looked at some video's about using templates to cut air foils so it'll be simple to make up templates for the different joints I want to create.(eg. box joint, dado). I'll have to start building some of the different cutters now. Figure a bow, scroll saw type and a router type and I'll have a flexible system for my potential foamie build. Just bid on a MRC Tech 3 on ebaypete42 wrote:When cutting foam with a hot wire cutter if you feel the wire pulling back you're going to fast,
if the foam is burning bigger than the wire you're going to slow
you will find a happy medium where there are some whiskers left when cutting.
and there will be some smell. I don't know how long a wire can be headed with a solder gun it may take more amps than than the gun can produce.
nice job you'll get it like most anything it's easy once you know how.
a fixed wire and foam pushed through it works great for flat cuts.
on airplane wings where you have to follow a shape it's harder but doable.
Pete
GPW wrote:Possible , but it would drain the batteries in 2.5 minutes.... Cut Quick !!!
