Babymoons on HF wheels---Has anyone else done it???
Postby LDK » Mon Jan 23, 2012 10:49 pm
I know of one forum member (georgeandpat) that did it successfully. I tried to replicate what he did but it didn't turn out very good. Actually the hubcap was on there really good but that was the problem, it was on there too good. It took alot of beating and banging just to get it off. When I did get it off it was dented and distorted. The plan calls for the wheels to be drilled and tapped with 4 quarter twenty round head bolts. It has to be position at the right place to hold the lip of the hubcap. I even tried to grind the bolt heads down some but that just made it where the hubcap didn't want to stay on. I even scoured the internet looking for hubcap clips and bought some but when I got them I realized they wouldn't work. I have even thought about trying to make some clips and if I did, what should I make them from?? If anyone has any ideas, please chime in.
Thanks
LDK
Postby Sparksalot » Tue Jan 24, 2012 2:59 pm
I used the friction fit version from Hubcap Mikes on my wheels. They look and work great.
Sparksalot
Images: 687
Postby LDK » Tue Jan 24, 2012 9:02 pm
Sparksalot wrote:I used the friction fit version from Hubcap Mikes on my wheels. They look and work great.
Did you use it on harbor freight wheels?? The problem with mine is the bearing hub sticks out almost 2 3/4". My hubcaps are about 9 1/4" dia. and have a 1" shoulder before it starts the curve. It just barely clears the bearing hub. I'm just gonna have to make some homemade hubcap clips to solve this problem. The question is, what to make them out of??
LDK
Postby reo-ron » Tue Jan 24, 2012 10:38 pm
You can get hub cap clips from Wheel Vintiques or Wheel Smiths. They are like the vintage 30-40's style wheel hubcaps retainers.
Ron
Old cars, trucks, trailers and scooters - bought, sold, traded and enthusiastically talked about.
reo-ron
Images: 23
Postby reo-ron » Tue Jan 24, 2012 10:49 pm
Most of those trailers use a 4 1/2 inch bolt circle wheels which are the same as old mustang & falcon 13" and 14" wheels also old mopars & AMC use this wheel. The 13"" are hard to find but 14" started in 1957 on Ford passenger cars and continued thru the early 80's. The 50's - early 70's have a center section that will take a nice baby moon type hubcap. I find most of mine at swap meets
Ron
reo-ron
Images: 23
Postby Sparksalot » Tue Jan 24, 2012 11:08 pm
I have a Red Trailers platform, instead of the HF. I never noticed the hub causing a problem, but also realized you are talking about baby moons and not the full moon disks that I used.
Sparksalot
Images: 687
Postby tomsglr » Thu Jan 26, 2012 3:21 pm
I read on another forum once that someone drilled a hole in the center of the hubcap. It didn't look too bad.
tomsglr
Images: 98
Postby LDK » Thu Jan 26, 2012 6:49 pm
I believe I'm just gonna try to make some homemade hubcap clips out of aluminum. I have alot of flat stock aluminum left over from building my camper. I have 1/16" thickness and 1/8" thickness. Who knows, maybe that will work.
LDK
Postby parnold » Thu Jan 26, 2012 6:53 pm
Larry:
Hub cap clips are usually spring steel. At highway speeds, I would be real nervous about aluminum clips.
parnold
Images: 302
Postby LDK » Thu Jan 26, 2012 7:26 pm
parnold wrote:Larry:
Darn it Paul, you put doubt in my head. :lol: What about thin 1/16" iron? Might be able to use a big vice and a hammer to bend it. :thinking:
LDK
Postby parnold » Thu Jan 26, 2012 7:30 pm
parnold
Images: 302
Postby LDK » Thu Jan 26, 2012 7:38 pm
I ordered some like these thinking they would work. Wrong.
They are way bigger than I thought.
LDK
Postby treemaker » Fri Feb 03, 2012 10:27 am
Maybe early VW clips?
treemaker
Images: 6
Postby LDK » Sat Feb 04, 2012 7:03 am
treemaker wrote:Maybe early VW clips?
I wonder how big they are?
LDK
