Wolffarmer wrote:On trailers the size that most are on this forum a battery is not needed. I do not know where the weight limit is where a battery is needed. Juat that I do not need to worry about it.
Randy
CARS wrote:I'm in a similar situation. '68 Dart, '70 Superbee. Both with horrible factory brakes (collecting parts for disc conversions on both of them). The other TV is a 80's Ford F-250. No issues there with a loaded car trailer. Should cut it!
I am torn. I was going to go with surge, but since the truck is already wired for electric, that might be the way to go. It wouldn't take much to wire the controller in the Dart, but making it look good in there... a different story.
(my car friends made fun of me for adding the hitch, can't wait till they see the controller!)
Wolffarmer wrote:When then fooey, I will just go without brakes and grind the ears off the axle for them to save even more weight. Easier to lose weight that way than diet and exercise.
Randy
CARS wrote:Do you have to add more frame clearance when you add brakes??
The electric kits don't look that "fat", but the hydraulic kits look like they would take up some room. Especially if you have a dropped axle.
Wolffarmer wrote:Another minus for surge brakes is that sometimes you have to pull the trailer down a hill. And that is exactly when the brakes work. If you are indeed "pulling it down the hill" the actuator isn't being actuated and the brakes aren't being applied. And I still would rather run electrical lines on the trailer than fit brake lines. Your choice. Need to determine the correct length of lines and get them. Not difficult if one can use a tape measure. Bend them without crushing them. Not difficult if you use an inexpensive tube bender (HF has em) or use a piece of 2" (or greater) bar stock as a form. Fasten them down so they don't vibrate. You should tie up your electrical wires so one 1/4" hydraulic line isn't much different. Put in fittings to go to a flex hose to go to the axle. If you can screw in a lightbub you can connect hydraulic lines. It takes great skill and a special tool to make the flares on them the "special tool is availble and it is steel tubing not copper. The tool isn't that expensive, is easy to use, and can be used on copper tubing to create a flare that is much stronger than a single single flare. Wiring is so much easier for the home shop. Having done both several times, not IMHO.
Randy
kirkman wrote: you have to lock them out when you back up
eamarquardt wrote: The tool: http://www.harborfreight.com/double-tub ... 66534.html
According to this video it's "very easy" to make a double flare: http://www.youtube.com/watch?v=usTvYMjwVdc
Installing hydraulic lines is not difficult but it is different than wiring and a number of folks are reluctant to try something new to them. Once you've done it a time or two, it isn't a big deal.
Cheers,
Gus
