eaglesdare wrote:hey mel, i am not sure if its been tried here yet or not (i just can't remember) but, have or could you do a test with the gorilla glue and the hot wire foam fushion glue?
i watched the vid of the guy testing that against wood glues. the guy had to really use some power to seperate the foam using that foam glue. was curious about gg.
i don't think gg is as good at all, because i can peel it right off when i get too much on my foam. but i never tried to really seperate any pieces once it has cured.
i am leaning towards using the hot wire foam fushion glue, but am still curious about the gg.
i do have a piece out back that i think has gg on it, i may go out and look. but its too cold right now.
I set up samples of 2" foam and glued one set of samples with GG, the other with the Hot Wire Foam Factory's Foam Fusion.
Here's the pic of the end to end joint
In front is the GG, In the rear is the FF
I let these samples cure for 36 hours and then put downward pressure on the joint until it failed. You can see that on the joint made with GG, the foam failed, on the FF joint, it came apart at the glue. After 36 hours the FF glue had not yet cured. It was still damp. On tests I had done previously with the FF on 1" foam pieces the glue had cured and the foam failed, the joint did not.
I do not recall with certainty, but I believe that I let the FF glue for much longer ( a few days) and at a higher temperature. It's probably mid 50 in the room I worked in. I may go out again and repeat the FF test and let it cure longer and let it cure in the warm part of the house.
So with certainty I can say that GG makes a good edge to edge joint. It also foams as it cures, so be ready to do some clean up while it cures
I also have face to face samples and corner joint samples that I am going to let cure longer before I test the bond to destruction. I'll post those results mid week
