windows
windows
Postby GLSmitty » Sat Feb 25, 2012 4:20 pm
Hi all, I'm new to this site and I came across it by fluke!!! Thought that I was the only one that thought about doing a CT conversion, LOL. Wow, was I surprised, and glad, when this site popped up. So I started looking through at all the pic that everyone is posting and I see some great ideas and layouts.
Well, I bought a used 2004 6x10 for $1200.00 with a side door, two barn doors on the back and a ramp to load my bike aboard. I'm thinking that windows are first in order, with wiring and insulation being next!! Which leads me to my question, a friend gave me two windows from a pick/up box cap that are 5 ft long, is it safe to be cutting out 2 metal studs to install these?? I was thinking of welding in a piece of 1" square tubing above and below the window the full length of the window.
Thanks to all who respond.
P.S.
I am located in Southern Ontario Canada, in a small town called Tottenham
Gary
GLSmitty
Images: 6
Re: windows
Postby BC Cargo » Sat Feb 25, 2012 8:53 pm
Welcome...I see no problem at all as long as you weld in the top and bottom suports. I installed my windows high just under the roof suport so the upper one was not required. I just will not let 4 feet of snow build up...
I like the high windows so no one can peek in and it helps clear the hot air from building up. Here are a few pic of what high mounted windows look like in and out and there are more pics if you click on my Album.
Ask any question and good luck. We all like to see pics :pictures:
gallery/image_page.php?album_id=51&image_id=85133&display=popup
gallery/image.php?album_id=51&image_id=85003&view=no_count&display=popup
BC Cargo
Images: 87
Re: windows
Postby pete42 » Mon Feb 27, 2012 7:10 am
Like BC said box in the window frames with metal should be no problem
I have owned travel trailers and on those rainy days I enjoyed sitting on the couch watching the rain
so I vote for windows low enough to see out when sitting down.
my needs will be different than yours I'll carry a mobility scooter you will carrying a bike.
pete42
Re: windows
Postby GLSmitty » Mon Feb 27, 2012 7:33 pm
BC Cargo, thanks for the input, I'm gonna go for it :thumbsup:
pete42, thanks. I had in mind to put them low enough to see out while sitting, but I'm going to put up an awning, so hope to be sitting outside most of the time, till the skitters drive me inside :lol:
Just starting the conversion, so there will be more questions to come......
Thanks
Gary
GLSmitty
Images: 6
Re: windows
Postby GLSmitty » Sat Mar 10, 2012 8:57 pm
Well I got the windows done!!! They are a little long but look great. Did some stud cutting and wielded in some headers and sills for reinforcements, cut out the openings and done the install. Now to do some wiring and insulating and then move on with the walls.... :D
888808888188882
GLSmitty
Images: 6
Re: windows
Postby BC_Explorer » Sun Mar 11, 2012 11:11 am
GLSmitty, those windows are a bit long but look great and will allow a lot of light in especially on cloudy days etc. Can you post some pics of the framing and welding you did around the windows.
BC_Explorer
Images: 19
Re: windows
Postby GLSmitty » Sun Mar 11, 2012 4:01 pm
BC_Explorer wrote: Can you post some pics of the framing and welding you did around the windows.
I only took a few, 2 already posted and a couple more here. Hope that will help.....8892288921
GLSmitty
Images: 6
Re: windows
Postby GLSmitty » Sun Apr 01, 2012 6:34 pm
Well, the windows are in and now I have started the insulation and some wiring. Hoping to finish the insulation over the Easter weekend and get the wiring all done. Here are a few pic of the progress I am making, slow as it is.
GLSmitty
Images: 6
Re: windows
Postby pete42 » Mon Apr 02, 2012 11:04 am
I know it seems slow to you I feel done right first time is better than doing it over.
nice so far keep up the good work.
pete
pete42
Re: windows
Postby Treeview » Mon Apr 02, 2012 12:40 pm
Are you spray foaming the ribs/framing to reduce thermal bridging? If so...any pointers?
Maybe you're not even worrying about the issue though.
Treeview
Images: 30
Re: windows
Postby GLSmitty » Mon Apr 02, 2012 6:55 pm
Treeview wrote:Are you spray foaming the ribs/framing to reduce thermal bridging? If so...any pointers?
No, not planning to, most of my camping will be done in the warmer weather, maybe spring and fall also but doubtful of any winter camping...
GLSmitty
Images: 6
