why don't the red circles turn to blue circles?
Hazel
S. Heisley wrote:Probably because somebody posted something else in the thread after you looked at it.
When you get done with what you want to see and you're ready to logout, go to the Board Index page, and, in the upper right corner, you will see a command:
"Mark all forums read"
Click on that and every circle should turn to blue. Then, the next time you log on, the only circles that will be red will be the ones that have had updates.
Dale M. wrote:S. Heisley wrote:Probably because somebody posted something else in the thread after you looked at it.
I asked Mike to make that a automatic on log out..... Maybe we need to ask again....
Dale
dmb90260 wrote:My main problem is the red circles are too thin and not obvious to those of us ( usually guys) with less than good color vision. The old forum had this big honking yellow blob in the middle which made unread posts very obvious. Unless I look closely I do not see the difference between the thin blue and thin red circles.
Now I check the dates and work my way back to the top. this works but is not efficient.
mikeschn wrote:dmb90260 wrote:My main problem is the red circles are too thin and not obvious to those of us ( usually guys) with less than good color vision. The old forum had this big honking yellow blob in the middle which made unread posts very obvious. Unless I look closely I do not see the difference between the thin blue and thin red circles.
Dennis,
You could always try the subsilver3 theme. It's not updated for the gallery yet, but it will be soon.
mikeschn wrote:
I can not make it automatic on logout. Sorry.
Users browsing this forum: Bing [Bot] and 6 guests
