Did I miss anything, about to start welding?
Postby Glenn Davies » Mon Mar 05, 2012 7:32 pm
sharpscan%40dannburg.com_20120305_102854.pdf
(70.7 KiB) Downloaded 55 times
Glenn Davies
Re: Did I miss anything, about to start welding?
Postby Glenn Davies » Mon Mar 05, 2012 7:50 pm
I plan on building a modified Benroy plan. I will be adding some curves on the front bottom and rear bottom, for an overall length of 10". I will be towing it with my '47 Chevy truck with air-ride suspension so i'll be sticking with the traditional 4' height.
Glenn Davies
Postby CARS » Mon Mar 05, 2012 8:31 pm
Your center of weight doesn't make sense, but that shouldn't stop your plan to weld.
My point is you are not taking the tongue into consideration.
Chris'
Autobody
Restoration
Service
CARS
Postby Glenn Davies » Mon Mar 05, 2012 8:33 pm
the front curve of the nose will over-hang about 2 feet over the front of the front frame?
Glenn Davies
Postby CARS » Mon Mar 05, 2012 8:39 pm
Glenn Davies wrote:the front curve of the nose will over-hang about 2 feet over the front of the front frame?
OK. I guess I should have researched your build design better. I'm building a Cub type of thing... It overhangs the same front to rear.
Chris'
Autobody
Restoration
Service
CARS
Postby Big Dave » Tue Mar 06, 2012 1:13 am
Glenn, stop screwing around, let's burn some metal!! :thumbsup:
It looks well thought out, but no mention of whether the tear will also be bagged? :worship:
You should start a build journal, it's pretty motivating.
Big Dave
